Overdue oilfilter change
Started by Jan Suhr, 20 July 2013, 15:44:43
mmcg
I've had two like that, astra 1.4 at 10k and omega dti at 2000 mls both aftermarket .
chrisgixer
Jan Suhr
Quote from: TheBoy on 20 July 2013, 22:22:18
Jan, if its been in there a while (the oil), it may be worth doing some short oil changes (eg, every 750km for a couple of oil changes).
I'm going on an vacation trip tomorrow and will drive about 2000km next week, I'll do a new change when I'm back.
Thanks for the advice  :y
Jan
Jan Suhr
Stockholm, Sweden
www.protouring.se
I've seen this as well, on a much less badly clogged filter. I reckon they can be crushed if they aren't on square when you replace the lid.
Quote from: Kevin Wood on 21 July 2013, 10:43:51
You've got to be pretty retardedham fisted to manage that surely :o
After all, the filter clips into the lid prior to refitting :-\
sjc
Boy am I glad mine uses the canister filters!
chrisgixer
Quote from: sjc on 21 July 2013, 13:12:18
Can't get those the wrong way round, I suppose.
Although are the innards the same sort of thing?
sdwall
Quote from: Jan Suhr on 20 July 2013, 22:13:32
I don't think it was wrongly mounted. The hooks that locks it in to the cap where facing outwards. But I think that the other end facing the block were stuck to the face of the filter and It might have been twisted when I screwed the cap off. The filter sort of hanged in there and I had to pull it out.
But I'm not sure about that, filter was anyway very worn and old. Flow through it must have been minimal.
Jan
Correct me if I'm wrong but aren't the hooks designed to lock into place INSIDE the holder, i.e. not showing?
Filter clips to the cap. Cap then screws into the housing :y Anyone fitting it backwards needs to get a desk job asap ;D
mmcg
Only ever happened me using one brand .
SR-71Blackbird
I took one out of an astra diesel that looked exactly the same as that , bloke said he had just changed the oil and filter  >:(
chrisgixer
mmcg
Go on... :)
[/quote]  Should i . spelt a bit like filter
mmcg
Go on... :)
[/quote]   Both  were foster I should return them to the factors , never had a problem with  mann ,bosch or any other brand.
