Pages: 1 2 3 4 [5] 6 7   Go Down
Author Topic: Problem with the 3.2 Elite  (Read 22085 times)
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Problem with the 3.2 Elite
« Reply #60 on: 22 July 2013, 20:47:52 »
Not since the mid/late '90s ::)
It's a faffy job to change the coolant though i believe and dangerous.  ....
how is changing coolant dangerous?  ???  ;D  ;D
Might accidental get it mixed up with squash and drink some??????  ::)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #61 on: 22 July 2013, 20:48:27 »
Poisonousness ain't it  ??? I'll do it when i change the expansion tank.. i know its a 50/50 mix but how much does it hold 6L ?
« Reply #62 on: 22 July 2013, 20:48:47 »
Robinson's barley water perhaps!  ;D  ;D  ;D
« Reply #63 on: 22 July 2013, 20:50:51 »
looking at the video, the coolant looks very pale. What are you using?
Trust me its clear and blue it's just the expansion tank that needs replacing.
That coolant isn't compatible with that engine. The corrosion inhibiters aren't designed for alloy components. Best be changing it sharpish :-\
Not quite correct - blue and green anti-frezes are compatible but are not long life - needing changing every 1 - 2 years max. Red a/fs usually give a minimum of 5 years protection.
Look here http://www.omegaowners.com/forum/index.php?topic=58120.0
« Last Edit: 22 July 2013, 20:55:05 by dbug »
« Reply #64 on: 22 July 2013, 20:51:16 »
Bucket under radiator drain, refill with distilled water. Run engine up to temp. Repeat until bucket is clear, then add 5 litres of red VX coolant, topping with 50/50.
Old coolant can be flushed down the toilet, not down street drains :y
« Reply #65 on: 22 July 2013, 20:52:02 »
Have you tasted the pink coolant? you wouldn't drink very much of it!! It's vile!  ;D  ;D  ;D
Capacity is around 10 litres, so drain it all from the rad tap, top it up with fresh water. Repeat till clear ie all the old coolant is out. Drop the coolant via the rad tap, pour in 5 litres of pink,  top up with fresh water .... that's it!  .... ish
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #66 on: 22 July 2013, 20:54:46 »
So it was done late 2011 so its due then  :-\
Thanks very handy..
Na i got some out the expansion tank to check it then put it back it.
« Last Edit: 22 July 2013, 20:57:24 by Mr.OmegaMan »
« Reply #67 on: 22 July 2013, 20:56:56 »
Hell of an echo in here ::)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #68 on: 22 July 2013, 20:59:36 »
One thing at a time mind got to get the car running first, Currently its just a paperweight  ;D ;D ;D
« Reply #69 on: 22 July 2013, 21:00:37 »
say again .......  ::) ;)
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #70 on: 22 July 2013, 21:01:06 »
« Reply #71 on: 22 July 2013, 21:01:31 »
« Reply #72 on: 22 July 2013, 21:40:51 »
Looking at the receipts it was done at a VX garage 2011  :-\
So overdue anyway then.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #73 on: 22 July 2013, 23:37:35 »
No point doing it really till i get hold of a new or used clear expansion tank, It's hard to see the level with this one just look at these pictures  :o
http://www.omegaowners.com/forum/index.php?topic=114643.msg1455049#msg1455049
« Reply #74 on: 22 July 2013, 23:44:17 »
No point doing it really till i get hold of a new or used clear expansion tank,  .....
Buy a new 'un  :y  :y  :y
Pages: 1 2 3 4 [5] 6 7   Go Up
