Author Topic: Parkpilot speaker  (Read 13244 times)
Re: Parkpilot speaker
« Reply #15 on: 21 July 2013, 19:06:14 »
Sensors are on their own loom, might be worth double checking the plug just before the loom exits the boot to behind the bumper :y
That said if the box can't 'see' that the car is in reverse, then the sensors won't be activated :-\
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #16 on: 21 July 2013, 19:41:10 »
Will do. It will now have to wait until tomoz. Fortunately the TD is my daily, and the 3.2 is on stands having had all the AC system dealt with, so I thought I'd deal with the PP while its off road.
Thanks again Al, I appreciate all your help. :y :y :y
Shackeng
  • Ramsbury
« Reply #17 on: 21 July 2013, 19:43:58 »
However all this is odd in that the speaker is also dumb. ??? ??? ???
« Reply #18 on: 21 July 2013, 21:09:23 »
Once its back driveable, if you want to pop round with it we can use some long wire and jump speakers/systems one to another and see what is working or not ?? But we go away a week tomorrow for a couple of weeks (France)... :)
Shackeng
  • Ramsbury
« Reply #19 on: 21 July 2013, 21:14:37 »
Thanks a lot Nige, I will probably take up your kind offer.
Cheers:y :y :y
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #20 on: 21 July 2013, 21:16:36 »
A fault with the sensors will send a series of beeps.
Not sure of the buzzer you are using..... I tried a front door speak from a Bose car and got nothing (it had resistors and stuff).... a simple PC speaker gave me instant results.
Shackeng
  • Ramsbury
« Reply #21 on: 21 July 2013, 22:07:55 »
This is just a 12v buzzer, works OK off a 12v battery, and I assume the signal to the PP speaker is 12v. :-\ I get no beeps or any noises at all at the moment. :-\ :-\ :-\
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #22 on: 21 July 2013, 22:28:51 »
No current from the PP control module when the car in reverse?
chrisgixer
« Reply #23 on: 22 July 2013, 01:08:10 »
Do the sensors tick, if touched lightly with pp engaged ? (Engine off helps as said)
The pressure applied to the centre of the sensor needs to be very light or the ticking will be smothered. Its quite subtle.
« Reply #24 on: 22 July 2013, 09:01:08 »
The speaker is a speaker, not a buzzer, isn't it?
Thus 12v across speaker would only give, at most, a quiet, single tick.
« Reply #25 on: 22 July 2013, 09:55:26 »
.. followed by a little whisp of smoke, yes.  ;)
Easy to replace with a speaker from an old radio, etc. IIRC we did this on one of Chrisgixer's cars due to a failed speaker.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #26 on: 22 July 2013, 13:22:53 »
Fairly sure RobG has used a Mig Tweeter in one of them, need to bypass the Cap and Coil (Crossover) on it though.
Shackeng
  • Ramsbury
« Reply #27 on: 22 July 2013, 15:22:40 »
As many of you will know, such language is foreign to me. :-[ :-\ :-\ :-\
Shackeng
  • Ramsbury
« Reply #28 on: 22 July 2013, 15:23:48 »
So if the speaker was OK I've now blown it up? :-[ :-[ :-[
« Reply #29 on: 22 July 2013, 16:17:23 »
On the plus side, you don't know that it was actually working beforehand ::)
Roughly translates to... use one of the small speakers in the front door by the handle, remembering to remove the little electrical component from between the terminals :y
I think...
Pages: 1 [2] 3 4  All   Go Up
Page created in 0.378 seconds with 20 queries.
