Pages: 1 [2] 3  All   Go Down
Author Topic: Omega GSM Antenna  (Read 7899 times)
Re: Omega GSM Antenna
« Reply #15 on: 27 July 2013, 11:18:30 »
I thought the FM aerial HAD to run down the PASSENGER side of the vehicle? Quote me if I'm wrong  :-\
Wrong
« Reply #16 on: 27 July 2013, 11:19:09 »
Grey is FM - unplug it and watch the radio stop ;)
« Reply #17 on: 27 July 2013, 11:20:57 »
I have a feeling mine does, but I might be wrong. It's been a while since I looked. IIRC, I have 2 unused cables that come up to behind the driver's kick panel. Easy way to tell which is which is to find them around the rear seat area (under the little armrest panel). The GSM one goes up past the seat back, up the rear pillar behind the trim and across to the antenna.
    • 530D M Sport, 330i Coupe
« Reply #18 on: 27 July 2013, 11:22:11 »
Scrap the information I gave you, that's only for the GPS and GSM combination antenna and loom
grain.ben
« Reply #19 on: 27 July 2013, 11:25:57 »
Wrong
Ok daddy  ;)
Thought it was, but I also thought they had to run down the pas side.
Ok nice one.
So, the black one it is, so I just need an FME coupler and some more wire then.
Im just going to pop out and have a look in the boot area for this wire to confirm my suspicions  :)
grain.ben
« Reply #20 on: 27 July 2013, 11:44:06 »
Right all sorted, just been out to the boot and found this, the grey FM wire and where my thumb and index finger are, the GSM cable wrapped up in some sort of foamy tape and they obviously run down the Drivers side, much to my surprise  ::) .
So, just need to get an FME coupler and some more cable to run behind the dash onto the pas side. Cheers all.  :)
grain.ben
« Reply #21 on: 27 July 2013, 11:52:41 »
Just one more question, I promise  ::)
Whats the frequency of the antenna? is it GSM 800mhz? I will be putting in a PAYG Voda sim in the unit, so will obviously run 2G.
« Reply #22 on: 27 July 2013, 12:01:51 »
900mHz
grain.ben
« Reply #23 on: 27 July 2013, 12:10:02 »
900mHz
Cheers Rob  :y
I'm done on this thread now haha  ;)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #24 on: 27 July 2013, 12:12:02 »
As Rob says its a 1/4 Wave for 900 Mhz, but you probably find it will run quiet happy as a 1/2 Wave at 1800 Mhz.
grain.ben
« Reply #25 on: 27 July 2013, 12:20:54 »
Cheers zirk  :y
Im installing a Nokia 616 standalone carkit which is why I want to make use of the telephone pre/wiring and the roof antenna  :y
(which runs 2G networks)
http://nds1.nokia.com/phones/files/guides/Nokia_616_UG_en.pdf
zirk
  • Epping Forest
« Reply #26 on: 27 July 2013, 12:32:15 »
Cheers zirk  :y
2G (The Generation Spec) can be 900 or !800 Mhz, so your probably find the Nokia Kit will run all Networks, with the exception of Three.
As said a few posts up, if you get stuck with the FME plugs and bits, Ive got some kicking around, I could always make up an extension cable for you.
grain.ben
« Reply #27 on: 27 July 2013, 12:50:28 »
Cheers zirk  :y
I might just take you up on that offer but it wont be until ive come back off my holidays in a few weeks time. I need a male to male coupler and a cable, approx. 2m long with female fme's on either end  :y
zirk
  • Epping Forest
« Reply #28 on: 27 July 2013, 13:00:25 »
Cheers zirk  :y
Why the coupler, think you just need 2m coax with FME Female and Male on each end.
grain.ben
« Reply #29 on: 27 July 2013, 13:03:02 »
Cheers zirk  :y
Oh yes, stupid me  :-[ , not thinking right today, got my sloppy brain on haha  :)
Pages: 1 [2] 3  All   Go Up
