Author Topic: Has anyone got a diagram of cambelt fitting,Please?  (Read 3553 times)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Has anyone got a diagram of cambelt fitting,Please?
« Reply #15 on: 22 July 2013, 19:31:21 »
Put the heater on full and make sure it's good and hot,are you sure temp sensor is connected?,if heater blows cold air suspect an airlock,don't,then run engine long like that as h/gasket could suffer
other rides
« Reply #16 on: 22 July 2013, 19:38:14 »
Just look at all that space us 2.2ers have.  ;D ;D ;D Enjoyable job to do  :y With enough space to have a barbie too  ;D ;D
but all cars should have moe doors than cylinders  :y  :y  :y
t'other way round, no?
.. unless you're a fan of the tin snail? ;)
It was hot when I typed it  :-[  :-[ ........ glad you were paying attention!  ;D
« Reply #17 on: 22 July 2013, 19:39:01 »
Monaro  ???
You knew what I meant!  ::)  ::)  ::)
« Reply #18 on: 22 July 2013, 19:43:07 »
Check the 2 temp sensors on throttle body have been reconnected
« Reply #19 on: 22 July 2013, 19:43:44 »
Oh, and as its your first time, forgive me, but check there is enough coolant in it
« Reply #20 on: 22 July 2013, 20:08:19 »
This is probably the cause, the sensor lead just push fits onto the sensor located at the right hand side of the block at the rear (next to the EGR Valve) :y
« Reply #21 on: 22 July 2013, 21:27:48 »
Monaro  ???
I know, but sometimes I like to take the pish  ::)  ;D ;D ;D
:y Thank you Tunnie,got one £3.75....that will do! (I think?)
Trouble is now the blooming temp gauge 'aint going up!!! :-\
Check the little brass connector on the back of the engine block, can easily pop off this is what feeds the dash gauge  :y
SandBoy
  • King's Lynn
    • 51 Plate 2.2CD
« Reply #22 on: 23 July 2013, 13:32:16 »
Thanks guys,will be checking it all on Thursday now (fitting in the time).
 Coolant Mix is 50/50 (using the red stuff?) - thank you for your help.
 Thought I had reconnected everything,but will double check as above.
Once again thankyou peeps, :ywill keep you posted on if I manage to sort it (or not)! ::)
