Author Topic: Drivers seat dead (electrically)  (Read 2495 times)
« on: 23 July 2013, 12:19:49 »
As above.Nothing,dead as a dodo. Have visually checked all fuses.All look ok. Tried 12v direct to the large red wire which enters the multi plug at the side of the seat,still nothing.Cant work it out. :-\
Re: Drivers seat dead (electrically)
« Reply #1 on: 23 July 2013, 12:33:11 »
IIRC PedroMV6 had the same problem with his pick up conversion :-\
Think he binned it before it got sorted though :-\ certainly he tried the obvious... fuses/live feed
Does the drvers seat have its own ECU for memory purposes?
« Reply #2 on: 23 July 2013, 12:53:58 »
Yes it does. Pretty sure it was ok a couple of weeks ago. :-\
« Reply #3 on: 23 July 2013, 13:05:22 »
A suitable hex driver in a drill should see the seat out with minimal fuss, then you can investigate further :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 23 July 2013, 13:12:58 »
Does the Motor get hot when you put 12v to it, or you may be able to feel a very slight knock in it?, if so sounds like its jammed, take it you have checked for the normal £1 coin etc in the runners.
« Reply #5 on: 23 July 2013, 18:01:36 »
No heat,no knocks no clicks,no nothing. I think Al is right.Will have to get the seat out and have a fiddle. :y
« Reply #6 on: 23 July 2013, 19:32:27 »
Sorted (kind off) It needed power to the thin red wire.Once I did that the seat worked fine.Doesnt matter why theres no power to the thin red wire,as its one the breaker and I just wanted to test the functions on the seat.
It all works fine,as do all 4 heaters - which is nice. :)
Thanks for the suggestions. :y
« Reply #7 on: 23 July 2013, 20:34:16 »
Look at guide to see what needs power for the ecu/motors to work :).  From memory, its 3 x 12v and 2 x 0v.
Heater is on its own plug.
« Reply #8 on: 23 July 2013, 20:40:42 »
Problem with testing heaters was that I had chopped through the looms behind all the switches when removing the dash wood trim. ;D
Wound all the wires round each other and tested them .All works fine.
Problem with drivers seat operation was probably also attributable to me chopping wires. Put 12v to the smaller red wire and ascertained that the seat all works ok. :y
zirk
  • Epping Forest
« Reply #9 on: 23 July 2013, 21:03:30 »
You need to stop fixing things on it Albs, the way your going with it there be nothing to break, your be selling it as a full working car. ;)
« Reply #10 on: 23 July 2013, 21:42:55 »
Only fixing things Ive broke to find out if something else is broke or not. ;) ;D
chrisgixer
« Reply #11 on: 23 July 2013, 23:51:21 »
Albs ! ::) I thought I was bad with electrics! ;D
Vega
  • The Netherlands
    • Omega Saloon 3.2
« Reply #12 on: 25 July 2013, 12:23:20 »
Fuse memory
F5 30A
F12 20A
F15 20A
Fuse Seat heating
F15 20A
F29 10A
« Reply #13 on: 25 July 2013, 12:48:56 »
Useful info. :y
