Author Topic: Replacing the standard audio with a single line cd/mp3/bluetooth head unit  (Read 2879 times)
SR-71Blackbird
  • Watford
    • 2.5TD Silver Auto Elite
Hi all,
Does anyone have any pictures of a replacement of the standard audio controls for a cd/mp3/bluetooth head unit?
Is it an easy procedure to do, I'm thinking of getting my local audio place to do something.
Thanks
Half hour job tops :y
Old unit out, possibly plug in adapter loom, fit new facia panel and cage, plug in new stereo, check it works and simply push into slot :y
SR-71Blackbird
  • Watford
Are there any pictures of ones after they have been installed?
Be some round here somewhere :y
Meant to add if your car is fitted with a Bose system, then the job gets alot more involved, as the system isn't compatible with anything :-\
If you have Bose, you need to replace the amp, and all the speakers, in addition to the headunit.  Obviously the display will be a tad miffed as well, and if GID/CID, become unusable.
SR-71Blackbird
  • Watford
Darn, yep I have the bose, ok that seems like way to much work, no problemo :)
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
To raise an old topic from the dead :)
Im going to be replaceing my Bose set-up in my Elite and have the display adapter/steering controls adapter for a Sony H/U. This is currently fitted in my Vectra that Im stripping, would the display adapter and steering control adapter work with the Omega's wiring...?
Or is it a case of suck-it and see...?
D.I.L.L.I.G.A.F...
Phil
Vectra B or C?
I swapped the soundlink/ Autoleads steering control adaptor from my 96 Vectra B to 99 Omega and it all worked fine, then put it in my 00 Facelift Omega and still worked fine - was a Sony hu btw
So would errr on the side of yes if its a Vectra B
minifreek
  • Wigan
Yes its coming from a '96 Vectra B ..... so should be OK :) happy days....
D.I.L.L.I.G.A.F...
