Author Topic: 2.0/2.2 exhaust manifold  (Read 1382 times)
omegod
  • liverpool
    • 2017 Seat Ateca
« on: 26 July 2013, 07:28:30 »
Are these by any chance the same part? need a replacement and can only find 2.0 ones in the scrappy
Re: 2.0/2.2 exhaust manifold
« Reply #1 on: 26 July 2013, 10:40:12 »
Although they look almost identical on the outside, the 2.0ltr manifold has extra holes in the upper flange. This is for the EGR pipework to connect to, which is totally different to the 2.2ltr setup, so no, unfortunately they are not interchangeable :(
The 2.2 manifold is the top one in this picture with the 2.0 below.
« Last Edit: 26 July 2013, 10:42:14 by PhilRich »
« Reply #2 on: 26 July 2013, 11:18:06 »
You can use the 2.0 one but you need to fill the holes.
This can be done by tapping them and inserting a suitably sized bolt
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #3 on: 26 July 2013, 20:13:29 »
Cheers guys , I don't fancy tapping cast iron to be honest so will keep looking!
SandBoy
  • King's Lynn
    • 51 Plate 2.2CD
« Reply #4 on: 27 July 2013, 12:35:22 »
Check your messages Omegod,you may be pleased! :y
