Author Topic: C30SE wont start..  (Read 2442 times)
Anderv26
  • Norway, Aalesund
    • Opel Omega B MV6
C30SE wont start..
« on: 27 July 2013, 02:25:35 »
Hi, i have a omega B MV6, witch i just fitted a c30se (3.0 24v) engine from a omega A 3000..
The problem is: I need either a wiring diagram for the ECU, or someone to tell me wich wires i will need to conect to make the ECU go "online"
The fuelpump is running, and the engine is cranking, the coil are conected and also working..
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: C30SE wont start..
« Reply #1 on: 27 July 2013, 08:44:26 »
this is the engine the omega's should have had.
Hoof'land storeman.
« Reply #2 on: 27 July 2013, 09:38:41 »
Not sure if electronic versions of the Senator/Caarlton wiring diagram exist. Worth getting a Haynes book of boollacks for a Senny?
« Reply #3 on: 27 July 2013, 10:53:51 »
Omegatoy/aka Graeme C is the man for this ....  ;)
2woody
  • Northumberland
« Reply #4 on: 27 July 2013, 11:28:42 »
the wiring diagram complete is in the Haynes manual for Carlton/Senator
Anderv26
  • Norway, Aalesund
    • Opel Omega B MV6
« Reply #5 on: 27 July 2013, 12:19:57 »
Was hoping i did'nt have to bye the haynes, alredy have the haynes for the omega B, and most wires are even the same color, but there are 3 wires left, and i don't wont to destroy the ECU by connect something to + that should be connected to - or something.. :p
