Author Topic: Locking Wheel Nut Key Numbers  (Read 1565 times)
BenjieH
  • Farnborough Hants
    • 2003 2.6 V6 CDX
« on: 27 July 2013, 17:17:27 »
Hi all,
I know that locking wheel nuts have been talked about quite a bit but I just wondered if anybody knew if you can still order replacement keys with a FS code? all the new ones seem to be just 3 numbers! The code I have is FS1740, Steelers were no help and the socket trick doesn't work because of the collar.
Any advice would be grand!
Tanks Ben
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Locking Wheel Nut Key Numbers
« Reply #1 on: 27 July 2013, 18:04:43 »
I can't help with the locking wheelnut key, but any tyre place worth their weight will have them off in seconds.
I usually weld a nut on the end, then wrench them off as normal.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 27 July 2013, 20:05:31 »
any good VX dealer should have a master set of them only 9 different codes,so 9 sockets. mr dtm might know the offical number.
Hoof'land storeman.
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #3 on: 27 July 2013, 20:53:08 »
Hi all,
Tanks Ben
You have to break the collar with a cold chisel then whack a impact socket on.  :y
« Reply #4 on: 27 July 2013, 21:07:03 »
Hi all,
Tanks Ben
Believe you can still get them from Vx - about £30 - try AndyC on here ;)
omega squared
  • london area
    • 335i/race car/2 x V6 est
« Reply #5 on: 29 July 2013, 11:47:36 »
yes vauxhall still do them not cheap though, very annoying its about £35 - we had to do it a few weeks back as said above you cant hammer a socket on due to the collar.
nothing tows better than an Omega estate in this price range
