Author Topic: Tow bar Electrics Grey Socket  (Read 2377 times)
m.ian
« on: 28 July 2013, 19:18:18 »
hi,
Noticed in car manual that there is a fuse (fuse # 27) for a "switched" power feed for the the above.
Does anybody know where the wire for this is or how to make the connection?
Thanks
Re: Tow bar Electrics Grey Socket
« Reply #1 on: 28 July 2013, 21:10:45 »
hi,
Thanks
it's the thick red wire in the towbar electrics socket somewhere in your 'boot' ....... not sure where it is in an estate  :-\
« Reply #2 on: 28 July 2013, 21:16:23 »
hi,
Thanks
Not "switched" in my motor .. permanently live .. :)
« Reply #3 on: 28 July 2013, 21:18:37 »
hi,
Thanks
No, it's not in my car either  ;) ....... I didn't read all the question. However, I'me sure the manual says a permanent 12volt  ???
A misleading question!  ;D ;D ;D
« Reply #4 on: 28 July 2013, 21:21:26 »
hi,
Thanks
If you want a 'switched' live for your fridge & caravan battery charging, you need a voltage sensitive relay ie one that switches when it senses there's more than 12volts going to it, when the engine is running.
m.ian
« Reply #5 on: 29 July 2013, 10:24:21 »
Fuse # 5 is for the continuous live for the trailer and yes it is the large red wire in the boot.
Have found that but want to find where fuse #27 out put is.
« Reply #6 on: 29 July 2013, 10:38:27 »
hi,
Thanks
Self levelling suspension & rear acc. socket ???
m.ian
« Reply #7 on: 29 July 2013, 14:37:02 »
discovered that this has nothing to do with the trailer socket  :'(
Thanks for the input anyway.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #8 on: 29 July 2013, 14:40:15 »
If you use one of the smart charging relays to connect up it will be a "switched" feed anyway as the relays don't run fridge/battery charging until they detect charge voltage after start up :y
other rides
