Author Topic: Reverse on Auto Box  (Read 1670 times)
m.ian
Reverse on Auto Box
« on: 29 July 2013, 14:40:07 »
Have recently noticed that when I select reverse sometimes the reversing lights and parking sensors are not activated!
Can anybody give instructions on how/if this is adjustable?
Note reverse gear is engaged OK
Re: Reverse on Auto Box
« Reply #1 on: 29 July 2013, 15:52:00 »
Tried wiggling gearshift
« Reply #2 on: 29 July 2013, 16:11:33 »
It'll probably be the selector switch starting to play up. Might be worth removing it and giving it a clean before it starts affecting the gearbox function as well.
« Reply #3 on: 29 July 2013, 17:06:07 »
Indeed, have a look around the selector switch
m.ian
« Reply #4 on: 29 July 2013, 17:23:14 »
OK is there instructions on the forum to do this?
« Reply #5 on: 29 July 2013, 17:45:35 »
Yep - in maintenance guides :y
« Reply #6 on: 29 July 2013, 17:50:10 »
Its bolted to side of box, partial obscured by starting cat (so don't attemp it if you've been using car ;D). 2 bolts, i large connector, and a nut for the lever.
m.ian
« Reply #7 on: 29 July 2013, 18:55:53 »
Ok great
will have a look if it stops raining long enough to do it :y
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #8 on: 29 July 2013, 20:59:16 »
Ok great
Rain? what the hells that ::)
« Reply #9 on: 29 July 2013, 22:02:31 »
Ok great
It's pissed it down at times today in this Bury!!!  :y :y
