Author Topic: Crank Case sensor oil leak  (Read 3418 times)
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
« on: 30 July 2013, 22:13:24 »
I've noticed a some oil seeping from behind the crank case sensor, next to the oil filter housing, is this likely to be the cause of the oil leak or will it be coming from somewhere else? Does this just need tightening, or is there a seal that's required? What size torx socket will I need to tighten the torx bolt?
thanks
Re: Crank Case sensor oil leak
« Reply #1 on: 30 July 2013, 22:15:34 »
as Andy suggested on your other post ....... are you sure it's not from your cam cover?
No idea of which Torx socket ..... but there's not that many in a set to choose from  ;)  ;) :y
« Reply #2 on: 30 July 2013, 22:17:28 »
More likely ;)
Small ;)
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
« Reply #3 on: 30 July 2013, 22:35:53 »
Both rocker cover gaskets where done 40k miles ago, are they likely to have gone again?
« Reply #4 on: 30 July 2013, 22:42:45 »
Pattern or OE gaskets?
If pattern, the answer is  ..... probably  ???  ;)  ;) and were the breathers done when the gaskets were? If not ..... then yes.
chrisgixer
« Reply #5 on: 30 July 2013, 22:44:40 »
Cranks sensor does have a seal/o ring on the sensor end. Could it have been nipped on fitting...?
« Reply #6 on: 31 July 2013, 18:00:43 »
From memory, the torx is E8...  ...though I always take a selection with me so I guess it could potentially be E10.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #7 on: 01 August 2013, 08:48:20 »
I have thought in the past that mine was leaking always a little oil in that area I have changed the seal but no difference I think that it might be from the seal on the cannister body to block but as my oil level never seems to change between oil changes I live with it. Is it correct that Omegas do tend to leak a bit and we put up with it.
« Reply #8 on: 01 August 2013, 16:16:09 »
chrisgixer
« Reply #9 on: 01 August 2013, 17:10:44 »
Don't they ever. Trying to think if I've seen a v engine that did NOT have an oil leak. Its surprising how many holes there are in the block that are sealed with sealant. I remain convinced they should be a gasket. Not a goo.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #10 on: 01 August 2013, 17:30:24 »
just pop off a HT lead and see if its covered in oil... that will tell you if your CC's are leaking  :y
RIP Paul Lovejoy
« Reply #11 on: 01 August 2013, 19:20:46 »
Have seen 'em leak just from outside seal Webs ;) - one of our old ones did that
« Reply #12 on: 01 August 2013, 19:41:34 »
TBE is pretty oil tight.  There, I said something nice about the car, I must be going soft ;D
« Reply #13 on: 01 August 2013, 21:27:01 »
Touch wood our 2.6 Estate is dry as a bone, no signs of any leaks
symes
  • oxford
    • R reg 940 volvo
« Reply #14 on: 01 August 2013, 22:10:11 »
now you've called the miggy gremlins out mate----
