Author Topic: Changing RH exhaust manifold on a 2.5 estate  (Read 1533 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 31 July 2013, 15:41:24 »
X84GND 2000 petrol 2.5 manual estate
FrankH described perfectly the sound my 2.5 makes these days. It began as a spitting when cold, now has developed into a growl.
Haynes makes changing the Rh exhaust manifold sound quite a job, involving removing the inlet manifold and flange, then some oil cooler and coolant pipes. Has anyone done it, and have they any tips?
Re: Changing RH exhaust manifold on a 2.5 estate
« Reply #1 on: 31 July 2013, 16:34:30 »
Remove inlet manifold.
Unclip & remove rear coolant hosework
Remove expansion tank.
Remove airfilter box
Remove transfer pipe
Remove heatshields and disconnect front downpipe
Remove ex. manifold.
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 31 July 2013, 17:31:08 »
Thanks Rob. Beautifully succinct. Now I can face the job. Haynes frightened me.
The car is almost due for a cam belt change. It is tempting to do it at the same time. Is there any reason why this is a bad idea?
« Reply #3 on: 31 July 2013, 17:41:48 »
Nope
