2003 Renault Scenic (1.6) - 8mm Square Drive sump plug?
Started by Webby the Bear, 31 July 2013, 17:56:21
that was the plug that caused me real headaches on clit.. as it was leaking , ended up welding inside and opening a new plug hole :-\
Quote from: Webby the Bear on 31 July 2013, 19:45:57
Quote from: Lincs Robert on 31 July 2013, 18:49:40
Quote from: Webby the Bear on 31 July 2013, 18:40:24
;D
I feel now I've had a bit of experience servicing cars.... these French cars are just stupid. the layout is terrible. fuel filters stuffed in wheel arches.... square drive sump plugs. etc why cant they be service friendly?  ::)
+1 ;D
This weekend I helped a pal having problems with his 54 reg Megane. The drivers window was stuck in the down position so we had to take the door card off. BLOOMING HECK  :'(.
The motor was mounted on the inside of the door card & not on the metal of the door itself. All the clips/screws were fitted in difficult to get to places. Makes an Omega door card look like a walk in the park ......
Hey ho
has he asked you to replace a head light or indicator bulb at the front yet?  :o :o :o :o :o if he does tell him to go elsewhere!  ;)
;D ;D ;D
Quotethese French cars are just stupid.
Well im going to agree with that  >:( >:( >:(
I got the sump key if you need one  :y
