Author Topic: strange rattling underneath ??  (Read 4991 times)
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
Re: strange rattling underneath ??
« Reply #15 on: 03 August 2013, 05:24:30 »
common ive found on lots of vauxhalls is brake pads rattle when handbrake released, when driving and rattling starts try applying brakes or just pull handbrake slightly so preasure applied(not to lock them as this would be dangourous) hth and cures your problem
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #16 on: 03 August 2013, 20:49:39 »
+1  :y
Toledodude1973
  • IPSWICH U.K.
  • 2002 2.6 elite,1973 ,Gas van,1974 victor fe
    • 2.6 OMEGA ELITE 2002
« Reply #17 on: 03 August 2013, 21:50:27 »
Last summer i had the window down and also heard a noise, more jingly than rattley though ,checked loads of things and turned out to be broken rear spring,only a small bit on the end was broken off but enough to cause noise on bumps. Only a thought but might be problem
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
« Reply #18 on: 03 August 2013, 22:47:10 »
But the handbrake operates shoes inside the disc on the Omega (and most Vauxhalls actually)  ;)
I agree... I broke the pig tail off a rear spring about 3 weeks ago and have exactly the same noise :y
worzelof10acrefield
  • Peterborough
  • Don't snort coke......You might drown
    • Vauxhall Omega 2.6 V6 Est
« Reply #19 on: 03 August 2013, 23:18:56 »
Hi.. same problem.... mine was brake pads not fitted by the previous owner correctly..
It's 106 Miles to Chicago, We've got a full tank of gas, Half a pack of cigarettes, It's dark and we're wearing sunglasses........HIT IT..
ree
  • Cambridge
    • omega 2.0 cd
« Reply #20 on: 03 August 2013, 23:28:07 »
yes tolido, thanks for the tip have not had those off as went tho mot no prob will have them off pronto tx bud, Ree.
REELUIN
