Author Topic: Tree Surgeon Advise  (Read 6560 times)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Tree Surgeon Advise
« Reply #30 on: 03 August 2013, 08:55:49 »
just gett the members of a caravan utilising nomadic travellers to remove it. :D :D
 or do as rods2 suggested, or is it time for oof'ers tree party :)
Hoof'land storeman.
« Reply #31 on: 03 August 2013, 08:58:45 »
How much space have you got for it to fall in any direction? as that will define how high up the trunk you will have to cut it?
Accurately getting it to fall in a particular direction is very straight forward. Rope the tree above where you are going to cut it. Tie the tensioned rope a concrete fence post or something non-movable like this, if it is not safe to have someone pulling on the rope. Cut a horizontal V in the direction of the fall about half way through the trunk and then cut through Horizontally on the other side about 1/2 way through the trunk about 25mm ABOVE the V. Put a metal wedge into the horizontal cut and hit with a hammer, this will start the tree falling. Obviously you need to be behind the tree, so it does not fall on you!
When cutting wood with a chainsaw it is important that the gap does not close as this can cause the saw to kick back. If you hire a chainsaw, make sure you have the proper gloves and ideally trousers. These both contain thin stands on nylon material which clogs the saw and stops it before you have taken your hand or a limb off. A chain saw can cut through a branch in seconds, it will go through a limb even faster!  :o :o :o :o
I was fortunate in that a friend of mine used to be a woodsman at Longleat and taught me how to use a chainsaw before I bought one for myself.
No, far too big sadly.
Did think about this route & employ some helpers  :)
Not sure I'd like to use a chainsaw, never have done so before.
Think I need to get some quotes in when the time comes and go from there  :)
Thanks all  :y
« Reply #32 on: 03 August 2013, 11:03:36 »
Thanks all  :y
 Don't worry If you accidentally lop off an arm or a leg. You have a spare. :y
The same does not apply to your John Thomas. :( :( :(
Okay...Petrolheads
« Reply #33 on: 03 August 2013, 11:07:14 »
What is the forgotten supercar pictured in my avatar?
The first correct answer wins an all expenses paid paid trip to St Lucia for two. Honest. :y
Whoops,  wrong section.  Mr Cretin meant to start a a new post. :-[ :-[ :-[ :-[
« Last Edit: 03 August 2013, 11:09:31 by Mr. Opti »
« Reply #34 on: 03 August 2013, 11:08:03 »
and that is why it's better to pay someone that has all the gear & experience to do it for  you rather than learning by your mistakes.  ;)  ;)  ;)
« Reply #35 on: 03 August 2013, 11:11:32 »
Exactly my thinking, at least to 50% of its current height. Then it will be far, far more manageable.  :)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Okay...Petrolheads
« Reply #36 on: 03 August 2013, 11:14:07 »
Looks like italian styling ???
other rides
chrisgixer
« Reply #37 on: 03 August 2013, 11:23:18 »
Winson woodcraft took 8 of those, in our garden, down to ground level for £350 iirc.
They are local to us, so probably not worth them travelling, nut should give a ball park figure.
It also depends how far they ave to haul the limbs to their chipper regards access.
But get a proper job done, tree felling is an easy way to removal of your own limbs if you don't know what your doing. ;)
« Reply #38 on: 03 August 2013, 11:24:38 »
Cheers Chris, I'd be very happy paying that kind of figure  :y
« Reply #39 on: 04 August 2013, 11:07:27 »
When healthy I'd be willing to help you out but, TBH, it's easier to get someone in to do it and clear the site too :y
Don't bother keeping any of the wood... It's no good for burning for heat anyway ;)
« Reply #40 on: 04 August 2013, 11:31:57 »
Fantastic offer, thanks  :)  :y
Wanted it just for outside fires, intend to get a fire-pit. (going to let it dry out for 12+ months first)
« Last Edit: 04 August 2013, 11:33:43 by tunnie »
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #41 on: 05 August 2013, 10:18:21 »
Cost.......One young fit man (You) and petrol chainsaw.
Total cost about £150. :y
If it was half the height, I'd easily take it on. Have to see, getting little ahead of myself here.  :)
I suppose it depends how close it is to 'breakable'  items.........e.g..... house.....greenhouse.......Omega 3.2 Elite. ::) ::) ::) :y
You forgot garage  ::) ::)
« Reply #42 on: 05 August 2013, 17:10:02 »
Garage.. Fire pit.. You know who to call. ;)
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
« Reply #43 on: 05 August 2013, 19:56:09 »
Let us know when you want it cut and I will see what I can do to help.  :y
Gaffers
« Reply #44 on: 05 August 2013, 20:03:19 »
I can ask my buddy in EOD if he has any Det cord spare.........how far away from he house did you want the tree to fly? :D :D
Pages: 1 2 [3] 4  All   Go Up
