Pages: [1] 2 3  All   Go Down
Author Topic: My air compressor has stopped working....  (Read 3886 times)
Debs.
« on: 09 May 2008, 17:06:40 »
I`ve got a Machine Mart air compressor (`given 12 years of good service now); a single stage mounted a`top a 39 ltr. accumulator.
It`s suddenly stopped working....the motor (visible at the fan end) still 'twitches' slightly when switched on (and hums a little), so I think the pressure switch is 'calling' correctly, but the pump refuses to start....the motor and compressor both turn and feel (as I`d expect) normal when turned by hand so I`d not suspect any seizure.
I wondered what the likely symptoms of a starting capacitor failure were?.....or perhaps the motor might be U/S...... Anyone got any ideas? :-/
HolyCount
Re: My air compressor has stopped working....
« Reply #1 on: 09 May 2008, 17:26:21 »
I am afraid, based on all my mechanical expertise, my only response is, have you tried kicking it ?   ::)
« Reply #2 on: 09 May 2008, 17:31:48 »
Or use the favourite fixit tool from my box.
A hammer.
Start with a small one and work your way up. ;D ;D ;D
Debs.
« Reply #3 on: 09 May 2008, 17:32:09 »
 ::) To my immense shame; yes!  :-[
« Reply #4 on: 09 May 2008, 17:38:12 »
If it's not been touched in 12 years ... depending how much use its had .. could be something as simple as worn brushes ??
Can you see any makers marks/descriptions etc on the motor ?
failing that ... Machine Mart customer servics with the model number ?
« Last Edit: 09 May 2008, 17:39:06 by entwood »
Debs.
« Reply #5 on: 09 May 2008, 17:44:01 »
Sorry Entwood: I should have said it`s worked fine for all of the 12 years I`ve owned it.....`till today  :'(
In my dealings with Machine Mart (water pump/generator etc.) their replacement parts costs are often higher than buying a brand new item....I guess that`s the idea.  ;)
« Last Edit: 09 May 2008, 17:46:27 by Debs. »
« Reply #6 on: 09 May 2008, 17:47:31 »
Sorry Debs .. I understood that from 12 years good service ...
I meant .. touched as in serviced .. ie brush changes etc  ... :)
Isn't English a wonderful language we all understand !!
 ;D ;D ;D ;D ;D ;D
haj
  • Brighton
« Reply #7 on: 09 May 2008, 17:51:55 »
spin the motor from the fan end then switch it on,if it runs the capacitor is naff.if dont run test the windings with a meter set to ohms or continuity.
If it has brushes remve rotor and check between commutator segments for continuity.
Failing that start at switch and check through.
Debs.
« Reply #8 on: 09 May 2008, 18:00:06 »
:) Thanks very much Haj will give that a test as you suggest, tomorrow. :y
Debs.
« Reply #9 on: 09 May 2008, 18:03:20 »
 ;D ;D ;D ;D ;D ;D
 ;D Hahaha :y.....you`re correct; not 'touched' (except for an oil change in the compressor) for 12+ years.....I just hope I can repair it; `can`t afford a replacement at this juncture.  :-[
HolyCount
« Reply #10 on: 09 May 2008, 18:28:10 »
 ;D ;D ;D ;D ;D ;D
I am touched to discover that it hasn't been touched in all this time, however, you would have to be touched to allow me to touch it!
Great language !!!
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
« Reply #11 on: 09 May 2008, 18:33:04 »
This is the perfect job for a Brummagem(Birmingham) Screwdriver!
They come in several sizes with a wooden or metal handle and sort out most problems.
I think other people call them hammers! [smiley=thumbsup.gif]
Sorry not taking the p~ss, just couldn't resist it.
Hope you get it sorted, if your luck is as good as mine it wll be U/S.
best wishes
Simon.
« Reply #12 on: 09 May 2008, 19:04:16 »
Could well be the starting capacitor IMO. As said, a nudge in the right direction might get it running in that case. They also have a valve to relieve the compression when starting in the pressure switch, however, I assume the air reciever is empty so that will probably not be it.
If it's the cap, any old capacitor with the correct ratings would fix it on the cheap.
« Reply #13 on: 09 May 2008, 19:15:58 »
Yes, likely to be an induction motor with a dying capacitor.
Debs.
« Reply #14 on: 22 May 2008, 16:36:33 »
Ok.....finally got `round to repairing my workshop`s air compressor; `thought I`d update the thread.
As suggested by Kevin: I tried removing the motor/fan cover and flicking the fan in the direction of normal rotation whilst applying power.....`no good, just the 50 Hz. hum from the motor but without motor power.
Checked out the overcurrent `breaker and pressure regulator switch which were both ok.
The starting capacitor appeared ok.....but with increasing desperation I removed it (it`s a 30uF.) and swapped it for the only one I had to hand; which was 30% physically-shorter and only 20uF. (off an old water pump)....wonder of wonders it worked fine and the compressor is back to normal. :y
I`ve been using the compressor it quite a lot since and the smaller cap. doesn`t seem to be making any difference to it`s starting/running.
I`m delighted to be having my Mr.-Blowy working again and I`m able to enjoy the use of my lovely air-tools once more....and for such a 'cheapo' fix...."A result!" ;)
« Last Edit: 22 May 2008, 16:43:52 by Debs. »
Pages: [1] 2 3  All   Go Up
