Author Topic: Another towbar wiring question  (Read 3430 times)
akula
    • Omega 2.6 Elite Auto
« on: 06 August 2013, 20:13:29 »
Took my car to an auto-electricians today to see about getting electrics fitted to my towbar for a spot of caravanning.
Guy seems to think because the omega`s have the bulb warning notifications on the on board computer , I might need to buy a genuine kit from Vauxhall.
Is this true or can he do it easily enough ? and if so how can it be done ?
Ive seen some people saying to use the supplied connector in the boot , others saying not to ,   peoples breake lights not working etc etc
Its a 2002 2.6 Elite Auto if that helps
Steve
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Another towbar wiring question
« Reply #1 on: 06 August 2013, 20:42:22 »
Use a 7 way bypass relay and it won't affect the bulb failure module,an auto electrician should know this :-\
other rides
akula
« Reply #2 on: 06 August 2013, 21:24:11 »
Thanks mate , ill tell him.
Also will he need to add a double plug seen as how its for a caravan ? one for lights , other for fridge etc ?
« Reply #3 on: 06 August 2013, 21:28:03 »
You don't even need the by-pass relay. Just wire it direct to what's already there.
If you want to extend the brake check to your trailer, there's another relay that's fitted up front you can fit (search OOF via Google) ...... most don't bother.
« Reply #4 on: 06 August 2013, 21:29:44 »
Depends what's fitted to the caravan.
If your caravan has a black (12N) & a grey (12S) plug, then yes. If it's a new caravan, it'll have just one 13 pin plug.  :y :y
« Reply #5 on: 07 August 2013, 08:48:48 »
Thinking out loud... When fitting the black and grey plugs to a car for the first time, is it feasible to fit a 13pin plug instead :-/
« Reply #6 on: 07 August 2013, 09:28:40 »
The 13 pin is the better system, but then you'd need to either alter the caravan or use an adapter - & then you don't gain anything, apart from a cable that then trails on the ground. ;-)
flymofred
  • nr. Tunbridge Wells (Royal)
    • (53) 2.6 Elite Estate
« Reply #7 on: 22 August 2013, 20:30:53 »
I see have Elite have got reverse parking sensors? And if so how do you stop them screaming at you as you reverse with a caravan on?
« Reply #8 on: 22 August 2013, 20:39:31 »
There are relays for switching them off. My Merc has an off switch for the sensors, but in reality I've rarely had need to turn them off ...... how often are you actually going backwards when the caravan is on the back?  ;) ;)
http://www.rydertowing.co.uk/products/towing-relays-monitors/other-bypass-relays
« Last Edit: 22 August 2013, 20:41:27 by Andy B »
« Reply #9 on: 22 August 2013, 21:40:44 »
When I enter maneuvering competitions with the caravan club, I simply unplug the speaker, there is a plug/socket on the cable from the control box, very easy access if you re-route the cable slightly, otherwise simply remove the spare wheel to access the plug/socket.
Otherwise I put up with the noise as its only for a very short while normally.
I_want_an_Omega
« Reply #10 on: 31 August 2013, 11:27:31 »
Er, why?
« Reply #11 on: 01 September 2013, 16:56:23 »
Er, why?
'cos you learn to do it better, simply put .. :)
It's easy to be a "pointer of a vehicle" .. there are 1000's of such idiots on the roads .. I try to be a "driver" .. by learning and improving all aspects .. :)
Page created in 0.022 seconds with 20 queries.
