My poor ol' Kwaka
Started by TheBoy, 08 August 2013, 22:02:29
Should point out, engine block is upside down
Quote from: TheBoy on 15 August 2013, 19:52:03
The Kwaka was pulled from the rubble today. This is all that is left (exhaust hidden in pic)
Sorry.. I'm not sure that's going to polish out. :(
Brake disk might be OK after a rub down... could be warped, though. :-\
At least you weren't riding it when that happened :-\
chrisgixer
The brake disc had a carrier and rivets in the middle, and where's tother one? :o
Quote from: chrisgixer on 15 August 2013, 20:59:14
The part just to the right of the disc is all that remains of the front wheel.  Other front disc is there, must have picked a pic before I found the last disc.
chrisgixer
That's the the front wheel spindle. So everything between the disc and spindle has melted. Both steel parts. All the alloy gone. (As you said somewhere, can't remember where)
chrisgixer
Actually. Can see the bottom of the fork leg has mostly melted away.
Good lord!
Quote from: chrisgixer on 15 August 2013, 21:17:31
The calipers are in that pile somewhere.
But ali stuff, all gone. As are the plastics, as you'd expect.
I'm still a bit in awe of how little is left, and I'm not just talking about the bike.
chrisgixer
Calliper carrier/slider pins are bottom left.
As far as I was concerned that garage was FULL. With just room to walk down the middle.
I find what little is left gob smacking tbh. Really. :o
Quote from: chrisgixer on 15 August 2013, 21:29:59
Yep, really shocking. :o
I bet you can't find the key for it, either. ;)
joshwyatt
At least the two most important items are still around, yourself and Sue!
Is the bike covered under the 'extended Omega warranty scheme'? I'll see if I can find my cheque book  ::)
I still can't believe how little of that Kwaka is left..
 :o :o
Think you will need new fork seals  :( But sure is a mess  :(
On the plus side, the jack looks well!  ;D
