TC fully skimmed oil
Started by Andy B, 09 August 2013, 14:18:29
Quote from: Webby the Bear on 10 August 2013, 09:36:22
it doesn't matter what oil you're using if you're doing regular oil changes. as long as its of SAE standard and of the correct grade for your car.
You'd like to think so, but sadly not always the case. OOFers know, for example, that some brands of oil cause far more mayo to appear in the filler necks and breathers on the V6 models, even on cars rarely used for short runs.
Webby the Bear
Quote from: TheBoy on 10 August 2013, 10:46:55
True but with most on here doing oil changes at 3-5k miles (half vx's specified recommendation) I wouldn't be concerned. just my opinion tho. :)
RIP Paul Lovejoy
chrisgixer
Quote from: Webby the Bear on 10 August 2013, 11:40:13
It's the breathers that are important though, as they pressurise the system when blocked.
Crap oil can give excess mayo=blocked breathers=pressurised crank case=leaking cam covers=oil in plug wells= miss fires and a wrecked ignition system.
The cam cover seals fail easily enough on their own without adding to the issue with crap oil. :)
Webby the Bear
Quote from: chrisgixer on 10 August 2013, 14:07:36
Fair enough chris.  :y :y :y
RIP Paul Lovejoy
