Pages: [1] 2 3  All   Go Down
Author Topic: help please.im stuck in Bristol  (Read 9567 times)
takemineanywhere
  • swindon uk
    • 2000 omega2.5td cdx
« on: 10 August 2013, 10:18:59 »
hi everyone.As above.Yesterday i drove from Swindon to Tenby picking up my girlfriend in Bristol on the way.Got there no Problems.Left car 4 hoürs .On retürning to car  started up ok but when driving goff i noticed heavy nochy steering.looked under bonnet & saw drive belt loose but not broken.Alternator not loose.. ....Eventually RAC turned up & diagnosed stuck/broken idler/tensioner.Of course he didn´t have one so its piggy back on his truck to Bristol to SWIMBOS house .Now i´m 40 miles from home with not many Tools &needing atensioner?......Rac wont take me home cos its the same Problem....Is there anyone in Bristol who can help me with this?I was thinking ROB orBROOMIES MATE as they know their stuff.Should i pm them?Help please.......The car is Facelift 2.5TD.Thanks,Paul
2000 2.5td cdx        1985 bmwr80rt
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: help please.im stuck in Bristol
« Reply #1 on: 10 August 2013, 10:26:04 »
Where abouts in Bristol are you mate?
If you can compile a list of tools needed, I'd be happy to pop over and give you a hand.  :y
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #2 on: 10 August 2013, 10:28:44 »
If it's the same tensioner as the petrol V6 then all you need is a 15mm spanner and whatever you need to take off to gain access to the belt
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #3 on: 10 August 2013, 10:35:08 »
http://www.omegaowners.com/forum/index.php?topic=90622.0
I don't know if its the same tensioner but I doubt it. You will need a 32mm spanner to remove the viscous fan if fitted. See link above. :y
« Last Edit: 10 August 2013, 10:36:59 by Shackeng »
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #4 on: 10 August 2013, 10:36:05 »
I've done plenty of V6 ones, never attempted one on a diesel though.
How hard can it be?  ;D
Shackeng
  • Ramsbury
« Reply #5 on: 10 August 2013, 10:37:22 »
Very easy, see guide link, which was not specifically for tensioner replacement but will help. :y
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #6 on: 10 August 2013, 10:44:38 »
Cheers - Does the Fan need to be removed then?
Other than that, just a 10mm Allen Key and 13mm Spanner by sounds of things?
Shackeng
  • Ramsbury
« Reply #7 on: 10 August 2013, 10:53:17 »
As I was doing the water pump I took the fan off, but trying to visualise it, I think you might get away without. The difficulty will come in trying to get the new belt (assuming one is going on) between the fan shroud and blades. If just the tensioner is going on with the old belt as a get you home, you may get away with the fan on. Let me know if you have any problems, I have got mine on the drive and will remove the covers to check if required. :y :y :y
takemineanywhere
  • swindon uk
Re: help please.im stuck in Bristoly
« Reply #8 on: 10 August 2013, 11:02:08 »
would be great if u could come over BM. i`m in St George Avonvale rd 78.my numbers 07714417236.have no Tools worth a shite.Paul
Broomies Mate
  • Bristol, UK
    • Stuff!
Shackeng
  • Ramsbury
« Reply #10 on: 10 August 2013, 11:12:44 »
Hmmm, I'd have to remove mine to be certain. I'll check it against my reg, and get back to you.
Shackeng
  • Ramsbury
« Reply #11 on: 10 August 2013, 11:17:20 »
Put my reg in ECP for a tensioner they say none found. That is just a bearing shown in your link, the tensioner is the whole unit with mounting. I believe it is possible to replace just the bearing, but I can't tell if that's the correct one.  :-\ :-\ :-\
Where's RobG when you need him? ::) ::) ::)
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #12 on: 10 August 2013, 11:18:23 »
I'll pop up to Vauxhall now and ask them.  I have this fella's reg number.
Cheers Shackeng!  :y
Shackeng
  • Ramsbury
« Reply #13 on: 10 August 2013, 11:27:05 »
According to my stealer, the bearing does not come seperately, but I'm not so sure, as, certainly on the V6 members have said it can be replaced. The whole tensioner part number is 9118848, and mine has none in stock, so I hope you get lucky. :y :y :y
Shackeng
  • Ramsbury
« Reply #14 on: 10 August 2013, 11:36:38 »
I don't think that is the correct bearing on ECP, that looks very like the deflection bearing pulley that sits next to the alternator, which ECP mentions. :y PM inbound with my phone number.
Pages: [1] 2 3  All   Go Up
