Author Topic: rubbing noise as clutch is disengaged  (Read 2981 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 18 August 2013, 15:11:09 »
T367KHL 2 litre petrol manual 188914 miles on clock
As I depress the clutch pedal with engine running I hear a rubbing noise as the clutch disengages. While held fully disengaged there is no noise; while fully released there is no noise. With engine not running there is no noise. Any ideas?
Varche
  • middle of Andalucia
    • Golf Estate
Re: rubbing noise as clutch is disengaged
« Reply #1 on: 18 August 2013, 16:03:46 »
Thrust release bearing perhaps? I don't know though as never had a manual Omega
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 18 August 2013, 16:24:29 »
Considered that, but it is silent with clutch held fully disengaged. Also it is not a squeal, just a rubbing or brushing noise, more like the lever or linkage brushing past a shroud or bush. But does not occur with engine dead.
mojzo
  • Slovakia
    • '00 Opel Omega 3.0 MT/LSD
« Reply #3 on: 18 August 2013, 17:53:44 »
Clutch bearing is only working when clutch is disengaged. So it seems it is worn.
« Reply #4 on: 18 August 2013, 22:08:07 »
A creak from the return spring on the pedal :-\
terry paget
    • 3 Astras 2 Vectra
« Reply #5 on: 20 August 2013, 13:55:01 »
Yes, it is that sort of a noise. But it does not do it with the engine not running.
« Reply #6 on: 20 August 2013, 15:22:30 »
Worn thrust release bearing ;)
terry paget
    • 3 Astras 2 Vectra
« Reply #7 on: 20 August 2013, 18:15:55 »
Thanks. I have never done a clutch, so know nothing about them. I had the impression that the carbon clutch thrust bearing squealed when worn out, and did it as long as the clutch was held disengaged. This one is silent when held disengaged.
« Reply #8 on: 20 August 2013, 18:41:27 »
Yep generally, but not always ;)
« Reply #9 on: 20 August 2013, 18:56:55 »
... the carbon clutch thrust bearing  .......
If it's like an Astra's thrust bearing, it's not carbon faced. I think carbon faced release bearings went out with the Ark  ;) ;) ;)
terry paget
    • 3 Astras 2 Vectra
« Reply #10 on: 20 August 2013, 20:10:10 »
Assuming the noise is release bearing, it won't suddenly fail, will it? Perhaps it will get noisier. There is no clutch slip.
So what are modern thrust bearings? Roller bearings?
« Reply #11 on: 20 August 2013, 20:12:45 »
It's a sealed unit .... you can't see inside, but I would think so.  ;) ;) ;)
terry paget
    • 3 Astras 2 Vectra
« Reply #12 on: 20 August 2013, 21:16:32 »
I still don't fully understand it. If it's clutch thrust bearing, it should make a noise as long as it is disengaged. If it's clutch pedal spring, it should do it with engine dead. I am perplexed.
