Author Topic: DA machine with extras  (Read 2586 times)
Re: DA machine with extras
« Reply #1 on: 19 August 2013, 20:06:33 »
few points
-its a compact size so will be light and easy to use..
- not sure about the warranty period ..
" variable adjustment 2500 up to 6800 r.p.m. guarantees perfect polishing performance."
2500 too high imo
personally I would recommend known brands like hitachi , bosch or dewalt :y
and one more point, after some time you will need to change its oil , so neds to be phsyically examined :-\
« Last Edit: 19 August 2013, 20:09:22 by cem »
razzo
  • Crapital
    • 97 3.0 Elite
« Reply #2 on: 19 August 2013, 22:14:26 »
gotta agree with Cem 2500 rpm as a minimum speed is too fast & will burn paintwork in no time, i mop 2k clear at about 1000-1500 rpm with g3, lube with plenty of water
« Reply #3 on: 19 August 2013, 22:16:42 »
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #4 on: 19 August 2013, 22:38:16 »
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #5 on: 19 August 2013, 22:42:15 »
And the Meguiars Dual Action Polisher Version 2 isn't far off at 1,800 - 6,800 rpm
http://www.amazon.co.uk/Meguiars-Action-Polisher-Version-included/dp/B0052WPZEW
What to do what to do  :-\
I could get the machine in the original #1 for around £80 with all the pads like this Link
« Last Edit: 19 August 2013, 22:43:59 by Mr.OmegaMan »
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #6 on: 19 August 2013, 22:47:22 »
Is the Omega pearlescent paint hard or soft paint (this is presuming its on its factory original paint) ?
« Reply #7 on: 19 August 2013, 22:57:54 »
I suspect Cem & Razzo are talking about rotary polishers (I doubt anyone would mop a car with a DA) rather than a 'dual action' or 'orbital' polisher..
I've used a DAS-6 with good results, the one in the link looks like it would be a lot heavier, though (basically a 4" grinder with a different gearbox, I suspect)..
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #8 on: 19 August 2013, 23:00:49 »
That would make sense  :y
Would you say for around £80 with all those pads etc. its not a bad deal ? Can't really take much more of polishing by hand...
I'm currently watching this one Link
« Reply #9 on: 20 August 2013, 12:39:00 »
never seen an original factory painted pearlescent omega :-\
but in any case it must be metallic paint with laquer..
« Reply #10 on: 20 August 2013, 12:47:09 »
makita has a da polisher sander with variable speed between 0-3000 rpm
meguiars is 1800 -6800..
checking the net
Speed Setting 1 - 1800 opm
Speed Setting 2 - 2800 opm
Speed Setting 3 - 3800 opm
Speed Setting 4 - 4800 opm
Speed Setting 5 - 5800 opm
Speed Setting 6 - 6800 opm
OPM's for G100/PC
Speed Setting 1 - 2300 opm
Speed Setting 2 - 2350 opm
Speed Setting 3 - 2600 opm
Speed Setting 4 - 3280 opm
Speed Setting 5 - 4780 opm
Speed Setting 6 - 6100 opm
OPM's for Meguiar's G110
Speed Setting 1 - 2560 opm
Speed Setting 2 - 3250 opm
Speed Setting 3 - 3950 opm
Speed Setting 4 - 4600 opm
Speed Setting 5 - 5550 opm
Speed Setting 6 - 6700 opm
OPM's for Meguiar's G220
Speed Setting 1 - 2760 opm
Speed Setting 2 - 3450 opm
Speed Setting 3 - 4150 opm
Speed Setting 5 - 5750 opm
Speed Setting 6 - 6900 opm
OPM's for UD Machine
Speed Setting 1 - 2660 opm
Speed Setting 2 - 3950 opm
Speed Setting 3 - 4130 opm
Speed Setting 4 - 4900 opm
Speed Setting 5 - 5240 opm
Speed Setting 6 - 6540 opm
OPM's for Griots 6"
Speed Setting 1 - 2500 opm
Speed Setting 2 - 3300 opm
Speed Setting 3 - 4200 opm
Speed Setting 4 - 5100 opm
Speed Setting 5 - 6000 opm
OPM's for PC7424XP
Speed Setting 3 - 4000 opm
 etc etc
but these are opm (-random- oscillations per minute) so definitely different unit..  :-\
however I can say that high speeds even oscillations not recommended during polishing as it will build up heat
« Last Edit: 20 August 2013, 12:49:00 by cem »
Page created in 0.025 seconds with 20 queries.
