Author Topic: Removing coolant pipe 2.5 V6  (Read 5178 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 20 August 2013, 20:24:43 »
X84GNB 2.5 petrol manual estate
Aiming to change RH exhaust manifold, following RobG and Haynes. Having uncoupled oil cooler pipes, and removed many hoses, Haynes says 'push oil pipes back', then 'slacken and remove the retaining bolts then remove from the engine'
The oil pipes do not push very far back. I get the impression there are two Torx screws holding the pipe to the head, but I cannot get at them, as the oil pipes are still in the way. Please advise.
Re: Removing coolant pipe 2.5 V6
« Reply #1 on: 20 August 2013, 20:31:13 »
Have you removed oil pipe at filter end? 19mm crows foot does nicely. Allows for better movement of oil cooler pipes  :y
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 20 August 2013, 20:48:18 »
Yes. I wonder if I should be more tough with them - wiggle and pull from below while wife pushed from above. The longer pipe oil cooler end obviously will not go far.
« Reply #3 on: 20 August 2013, 21:17:36 »
What ever you do, don't bend them. Whole world of pain then, free them off next to oil filter/crank sensor, should give enough room to move oil cooler pipes out of the way.
terry paget
    • 3 Astras 2 Vectra
« Reply #4 on: 20 August 2013, 21:39:08 »
Thanks for that advice. This job is getting ever more difficult. Maybe one of them is still located in the hole in the block. Tomorrow I will check they are both free, then try again.
JayMV6
  • Reading
« Reply #5 on: 20 August 2013, 22:31:57 »
Cant remember 100% but dont the pipes have a clip that holds them together. Black rubber with a metal clip tht holds them. Like i said could be wrong  :o
« Reply #6 on: 20 August 2013, 23:25:08 »
Correct. :y
terry paget
    • 3 Astras 2 Vectra
« Reply #7 on: 21 August 2013, 13:11:31 »
Correct. :y
Could not see a clip. The crank sensor lead seemed to be in the way, so I cut it and removed it. Not much better. I can now see a Torx male bolt on LHS of pipe, and feel one lower down. However, access is grim. I cannot believe Haynes would have ruled this an engine in car job on this basis. If I do get the pipe off I shall never get it on again.
 Looking from below, a heat shield on LHS exhaust down pipe seems to be in the way. Picture follows. I am tempted to hammer it up out of the way, or saw it off.  Please advise.
[img src="https://www.dropbox.com/s/dedr22jj5ealsx0/DSCF2266.jpg"][/img]
« Last Edit: 21 August 2013, 13:17:05 by terry paget »
« Reply #8 on: 21 August 2013, 13:30:52 »
If you're aiming to remove the manifold, you need to drop the exhaust any way, might help access :-\
terry paget
    • 3 Astras 2 Vectra
« Reply #9 on: 21 August 2013, 14:35:43 »
Thanks for the thought. I was only planning to drop the RH side down pipe, possible removing it. It's the LH side heat shield in the way, and that's attached to the LH manifold, which Haynes says is very hard to remove, either engine out or head off. I keep feeling I am missing something. It is a 4 spanner job to Haynes. I have done lots of 4 spanner jobs. I fear this time I have met my Waterloo.
terry paget
    • 3 Astras 2 Vectra
« Reply #10 on: 21 August 2013, 15:55:30 »
With my wife pushing the oil pipes backwards, I could see from below that what was obstructing their movement backwards was the heatshield. I tried bashing it with a drift, but it is springy. I suppose I need to get hold of it and bend it out of the way. I can't imagine how to do that. Possibly attach something to it and haul from above. All suggestions appreciated.
« Reply #11 on: 22 August 2013, 17:26:06 »
If it's the off side manifold you are doing there is no need to remove the oil cooler pipes ;)
terry paget
    • 3 Astras 2 Vectra
« Reply #12 on: 22 August 2013, 19:33:50 »
Is that right? Haynes says I must, and I cannot see how else I can remove the transfer pipe. Please enlighten me.
« Reply #13 on: 23 August 2013, 06:54:28 »
Remove the coolant bridge instead and use a long 8mm socket on the torx bolts of the transfer pipe. I must have done about half a dozen like that :y
terry paget
    • 3 Astras 2 Vectra
« Reply #14 on: 23 August 2013, 07:32:06 »
And you obviously managed to get it back on again afterwards. Thank you very much. I am learning that on the V6 engines one has to work by feel half the time. I have unbolted the two oil pipes, and can see the LH bolt, and feel the RH bolt. You say a long 8mm socket is the tool to use. I shall persevere.
