Author Topic: lost key transponder chip  (Read 7576 times)
dbdb
  • west london
  • Tramlining,Trade Club,WIM,my time racing,Linux etc
    • f/l elite 2.6 V6 manual
« on: 21 August 2013, 20:20:53 »
Came to use my spare key today and engine just turns over.  On inspection the transponder chip has fallen out, probably happened the last time I use the spare key and it came apart.
So am I right in thinking I need to either live without a spare key or get a second hand or blank key with chip in eg http://www.ebay.co.uk/itm/160575925383 and find someone with tech2?
Re: lost key transponder chip
« Reply #1 on: 21 August 2013, 20:51:20 »
 ;D ;D Yep
« Reply #2 on: 21 August 2013, 21:06:34 »
Spare key is the best solution. You need a carpass as well.
Bodge Plan B is to remove transponder from working key, and tape it to the immobiliser ECU.
dbdb
  • west london
« Reply #3 on: 21 August 2013, 21:08:35 »
;D ;D Yep
No need to toss yourself off dbug its only the spare ;D ;D ;D ;D.  I still have a working main key ::)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #4 on: 21 August 2013, 21:25:49 »
Cheaper here presuming you dont need the blank key part...
Link
« Reply #5 on: 21 August 2013, 21:28:41 »
I have a spare chip FOC if anyone wants it  ;) ;) ;)
dbdb
  • west london
« Reply #6 on: 21 August 2013, 21:36:45 »
Read somewhere that second hand transponders cannot be re-programmed and I need a virgin chip;)  Is that right?
Also what is all this guff on the bay:
"Vauxhall Key re program remote
IMPORTANT
- These instructions will not take effect if is used second hand or new bought key from some were else.
- Must be original key that belong to the car from original.
Instructions is to program key to work with central lock of your car.
 - NO KEYS ARE FOR SALE HERE!! THIS IS INFORMATION ONLY PHOTO FOR ILUSTRATION PURPOSE ONLY
- To comply with UK eBay rules and regulations we will POST you a hard PAPER copy of the INSTRUCTIONS .
Want To Program Your Car Keys?
HAVE YOU CHANGED THE BATTERY OR DROPPED THE KEY AND LOST THE CODE? AND
CENTRAL LOCK IS NOT WORKING ANYMORE?
HEY THIS IS EASY TO FOLLOW GUIDE TO PROGRAM BY YOURSELF THIS KEY.
VAUXHALL
ZAFIRA,CORSA,ASTRA,VECTRA,OMEGA,FRONTERA,ETC...
THE INSTRUCTIONS YOU NEED TO REPROGRAM YOUR KEY FOB.
Has Your Car Key Stopped Working? Or Dont You Have Central Locking? These instructions will Help You On Your Way! Remote Keyfob Programming: Instructions
This is a detailed step-by-step easy to follow instructions on how YOU can re-programme your keyfob. This works for MOST models. The information you are buying comes directly from dealerships, And trained mechanics with many years experience - Dealerships normally charge approx £40 + VAT for the information / or do it for you.  The Instructions Will Be Dispatched within 24 hour of payment recieved - Please note this only takes no more than 5 minutes to do once received! WHAT'S YOUR BENEFITS : Info 100% Genuine, Works on MOST cars, Takes five minutes, Will save you money! (£40+vat) Dealer Charges
** Please note ** This information we supply works on 99.9% of cars, But please understand that there may be an actual fault with the key fob you are trying to reprogram, This may not allow you to re-programmed it at all. This only reprograms the lock/unlock/central locking/alarm fob however it does NOT reset the key chip immobilizer. If you have any problems i will be happy to help, please contact me before leaving negative or neutral feedback Please note because of the nature of the item no refunds will be given.
dbdb
  • west london
« Reply #7 on: 21 August 2013, 21:38:14 »
Yes please will send you an SAE :) :)
« Reply #8 on: 21 August 2013, 21:51:46 »
PM replied to  ;) ;)
« Reply #9 on: 21 August 2013, 21:58:09 »
You need programming equip and the carpass to program the immobiliser.
dbdb
  • west london
« Reply #10 on: 21 August 2013, 23:27:40 »
I don't have the car pass, I think it tells you to keep it separate from the car and the previous owner obviously did :(. And I forgot to ask for it not that  that would have helped.  So I have to go to Vaux for the car pass do I?
Re. programming I assume it is the car that gets programmed not the transponder I assume that is passive?
Had a quote of £20 to supply and program a chip IF I have the car pass/security code which doesn't seem too bad for London.
« Reply #11 on: 21 August 2013, 23:48:26 »
Have a ring around for prices for a Car Pass. Apparently they range from £20 to £50 .... depending on the dealer. Vx Wigan charged me £20 +vat  for a a replacement for mine ...... then I found the original  ???
« Reply #12 on: 21 August 2013, 23:56:54 »
;D ;D Yep
Don't think that's called for - only confirming that for once your thinkng was right ???
And "all the guff on the bay" will be merely how to resync your remote fob. ;)
« Last Edit: 22 August 2013, 00:00:14 by dbug »
dbdb
  • west london
« Reply #13 on: 21 August 2013, 23:59:23 »
thanks that's now coming up to £50 plus :(.  TB's ingenious bodge Plan B is looking more attractive.  Another advantage is that I will never lose a transponder again :).
I assume all VX have to do is check their database, check you are the owner and print the pass.  £20 a minute  >:(
« Last Edit: 22 August 2013, 00:02:41 by dbdb »
dbdb
  • west london
« Reply #14 on: 22 August 2013, 00:00:36 »
;D ;D Yep
Is two smilies not an orgasm for you? Sorry thought it was. :-*
