Author Topic: Not the usual CCR2006 problem  (Read 3340 times)
Rog
« on: 24 August 2013, 12:05:44 »
I recently got a replacement CCR 2006 for my 03 MV6. The old one is sitting on a desk waiting for me to try and remove the CD cassette   :(
Everything works. BUT it will not autotune, it will not move to the next available satation etc etc
It wil tune, but only manually by moving up the frequencies by pressing the arrow button repeatedly and listening
AS does not work it just scans continuously
I have tried with RDS on and off
I have tried different "U" channels
I have tried TP on and TP off
If I find a station manually and put it into memory it does remember it but does not show the station name
I've pushed every button on and off that there is
Any ideas ? It it knackered or am I missing something stupid ?  ::) I'm fairly familiar with these I've been driving Omegas for many years.
Re: Not the usual CCR2006 problem
« Reply #1 on: 26 August 2013, 09:16:26 »
If it wont show station name (and rds in enabled), that points towards weak signal. Whether thats external or within the tuner, who knows.
IIRC, you also have a broken 2006, which gives scope to make one good one?
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #2 on: 26 August 2013, 23:49:35 »
Is the aerial to the radio in the rear window with that amp thing under the back parcel shelf  :-\
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #3 on: 27 August 2013, 09:44:06 »
Not uncommon to fracture the delicate aerial connector at the back when swapping them out
Radio & Decoding Technician
www.dndservices.co.uk
sdwall
  • Walsall
  • Nil illegitimum carborundum!
    • '03 2.6 V6 CDX Auto Est.
« Reply #4 on: 27 August 2013, 09:51:45 »
On a different note, is it normal for the head unit to switch off in one mode and switch on in another mode?
(switch off ignition with Radio playing and switch ignition back on later and CD plays)
That's what mine does sometimes!
Rog
« Reply #5 on: 27 August 2013, 17:02:15 »
True. If I can be arsed  ::) Actually probably not that hard to do  :) . . . but not yet
Rog
« Reply #6 on: 27 August 2013, 17:04:21 »
Thanks. Good point. And given that they are always soooo very easy to remove . . . LOL
( Actually, things are so much better since I made my own removal tools  :y )
  • Auckland
    • Mazda MPV
« Reply #7 on: 27 August 2013, 17:27:24 »
It may not even be broken. The plug has probably come unclipped and fallen out of the back of the radio cage.
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #8 on: 30 August 2013, 06:42:11 »
There was a working unit in the box of bits that was at wycombe  :y
Rog
« Reply #9 on: 31 August 2013, 09:54:43 »
It went pretty quickly, and I didn't know about this at the time. I wasn't going to take it just 'cos it was there.
LFF64
  • HADDENHAM BUCKS
« Reply #10 on: 02 September 2013, 20:24:40 »
It was a working one I only swapped with another one as I had pulled the front off of it getting it out  :-[ there were some spare CD holders there too  :-X
