Author Topic: Self levelling shock failure, heads up.  (Read 4351 times)
Re: Self levelling shock failure, heads up.
« Reply #15 on: 26 August 2013, 11:52:48 »
.... and put some copper grease on the tube, that should give some good protection.  :-\
Did you get the OK from Chris first?  ::)  ::)  ::)
« Reply #16 on: 26 August 2013, 15:22:14 »
Hopefully mine won't snap before I get chance to fit the replacements!  :y
Especially as I need to go and strap a shed to the roof of the car shortly (flat pack, obviously..)  :-[
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #17 on: 26 August 2013, 16:23:13 »
 ;D ;D ;D ;D ;D ;D
chrisgixer
« Reply #18 on: 26 August 2013, 17:20:38 »
Of course he didnt. :P
« Reply #19 on: 26 August 2013, 19:06:00 »
SL's on the 3.0 Elite did got like that too, MotherT had not noticed  :o
Shit happens really, amount of muck and salt on the roads its to be expected. Plus parts to a cost, GM exhausts were a very visible drop in quality as you could see it.
Suspect same with others parts, just can't tell so easily
« Reply #20 on: 27 August 2013, 09:33:09 »
I didn't notice mine were on their way out until it totally failed, and even then it just felt 'odd' rather than feeling classically like a dead shock.. I think that's because they're so soft normally anyway. Now, with it totally failed, it feels like the car is going to fall over in a left hand corner ;D
chrisgixer
« Reply #21 on: 27 August 2013, 19:26:12 »
Ime, when the shocks fail, which is at the point the oil leaks out, often accompanied by an odd fizzing noise from the rear of the car, the most obvious symptom is the wheels bouncing off bumps and banging as they land back on the road after the bump.
A typical sign of lost damping. The ride height should remain stable at least initially,  if not necessarily the same. So I wonder, does AaronJB have a buggered spring as well? :-\
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #22 on: 27 August 2013, 22:34:26 »
Acctually mine went BANG because of a ferking big pot hole in the dark.  >:( >:( >:(
chrisgixer
« Reply #23 on: 27 August 2013, 22:56:18 »
What, burst the bladder? Lordy. :o
Or collapsed the shock?
« Reply #24 on: 27 August 2013, 23:23:40 »
I don't think so - certainly nothing looked broken when we were under there last week.. There's just no damping going on so the car is free to wallow over in corners (but only one corner of the car, so it feels like the back end drops as you load up that side of the suspension)..
Ride height at rest is still even on all corners.
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #25 on: 28 August 2013, 00:20:20 »
the bottom part rusted and then went spectacularly when I went over a pot hole,  >:( >:( as in photos.  :y
« Reply #26 on: 28 August 2013, 10:32:47 »
Rear shocks rusting throguh has been happening for as long as I can remember, seen it on Triumphs, BMW's, Rovers, VAG the works.
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« Reply #27 on: 29 August 2013, 14:21:38 »
Stumbled access this pic the other day. On a sales thread by Paul K.
Hope he doesn't mind me pinching it copy and paste style, but I thought it was a bit if an eye opener tbh. I've seen oil leaks from sl shocks, and the severe rust around the shock body under the bladders, common sense suggested that 2+2 should go together and mean the oil was leaking from the rusted shock body and if left long enough the thing would snap off.
But I had trouble believing the metal was so thin, and didn't quite believe it. WRONGGGG!
Here's the proof. But how to stop it..?
No that's fine, help yourself lol... Although the photo was in my gallery thread ;-)
chrisgixer
« Reply #28 on: 29 August 2013, 14:55:17 »
....beg your pardon Paul, my wording implies entirely the wrong thing.
sincere apologies. :-[
I,ll see if admin will alter it.
P6UL K
  • Dartford, Kent
« Reply #29 on: 29 August 2013, 15:21:15 »
Honestly Chris don't worry about it it's no biggie  :y
