Pages: 1 [2] 3  All   Go Down
Author Topic: Exhaust manifold off; need advice please  (Read 6324 times)
symes
  • oxford
    • R reg 940 volvo
Re: Exhaust manifold off; need advice please
« Reply #15 on: 27 August 2013, 13:33:38 »
as for crack in manifold---try Frost Restoration :y they do stuff for that----and it works--saves lots of p*****g about :y :y
chrisgixer
« Reply #16 on: 27 August 2013, 23:09:07 »
Would metal 3.2 gaskets be better? Don't know if they would fit..? Or indeed, is it worth fitting 3.2 manifolds? (If 3.0 un available maybe)
I was going to suggest welding the crack, but would the manifold distort in the process?
Defo blowing and cracked though. So we where both right :y
Sorry Terry. More questions than answers. I've experienced the symptoms, but not done the repair. :(
Interesting notes on the studs. :)
The 2.6/3.2 is a better manifold and should flow better to (it does fit) but the gaskets are not interchangeable.
Welding cast iron is an art form, not easy and you need to drilling the crack ends to stop spreading first (which many dont bother with)
...now you mention it, some of our older machines at work have exposed cast iron connecting rods. Which some gorilla broke.
The resulting bodge Weald looked like boiling pigeon poop pored over a red hot hob that had run like mercury. The repair didn't hold. None of the weld had penetrated, and none of the cast iron join had melted in any way. How it lasted as long as it did was beyond me.
Sorry Terry, bad idea. :(
« Reply #17 on: 28 August 2013, 00:35:03 »
Can be done using specialist rods & specialist welder - probably easier to replace though ;)
« Reply #18 on: 28 August 2013, 09:22:18 »
I have welded cast a few times but, it requires a high carbon rod and needs massive pre and post heat to prevent cracking.
If its a small non loaded part then drilling the cracks at each end followed by a spot weld and tap approach works well (create a small molten pool of metal and as it cools tap rapidly with a ball pein hammer to minimise stress in the joint)
« Reply #19 on: 28 August 2013, 09:42:38 »
Since you only have one side off, there is no point putting on a 2.6/3.2 manifold because you will have an imbalance of course. You will also need to use a 2.5/3.0 gasket cos you'll have the SAI system.
If you were doing both sides, I'd say go for the 3.2 manifolds and gaskets and bin the SAI system and EGR valve completely.
how .. you can block EGR valve but cant disable it from the ECU.. only dbw ECUs dont have egr but they will require other setups.. as far as I know only in some astras it was possible to tell ecu you dont have egr :-\
« Reply #20 on: 28 August 2013, 09:46:32 »
Correct Cem but you can make an EGR simulator circuit to repalce the valve with.
« Reply #21 on: 28 August 2013, 09:48:27 »
I have done a "special design"  ::) ;D  may be you will remember ;D ;D :y
and upto now cant see any negative side effect :)
« Reply #22 on: 28 August 2013, 09:59:08 »
But think of the benefits of replacing that heavy valve with three resistors, a diode and small relay  ;D
JayMV6
  • Reading
« Reply #23 on: 28 August 2013, 19:43:20 »
Make sure you add a new "o"ring to the shopping list for the coolant pipe that comes off of the back of the block. Only cheap and I wouldn't re-use the old one.  :y
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #24 on: 28 August 2013, 19:55:42 »
Drivers side is not hard to do, three-four hour ish job
I see it's the driver's side that's already off - how long to do the passenger side?  Easier or harder?
« Reply #25 on: 28 August 2013, 21:25:57 »
The hard thing about the passenger side is that all the work needs to be done whilst lying on your back
« Reply #26 on: 28 August 2013, 21:31:58 »
some may not agree, but if there is a lift handy I would take out the engine (instead of changing those seperately) and do many other jobs at the same time as those are old cars anyway.. :) so you wont need to work under the car over and over..
« Last Edit: 28 August 2013, 21:33:46 by cem »
sjc
  • Alloa, Scotland
« Reply #27 on: 28 August 2013, 21:41:40 »
Yeah, engine comes out fairly easily once you get the radiators out.  I only put the coolant one back and ditched the AC.
Shallow Al
  • Lymington, Hampshire.
    • 3.0 Litre Elite.
« Reply #28 on: 29 August 2013, 00:20:16 »
The JB weld stuff?
Have you used it? Any good?
I used to know everything. Then I got married.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #29 on: 29 August 2013, 20:13:54 »
Thanks. I did not know it was an O ring. The pipe was stuck on the head and took some prising off. It was a nightmare getting the screws off; goodness knows how I shall get them on again.
Pages: 1 [2] 3  All   Go Up
