Author Topic: ceiling light  (Read 3784 times)
AndyRoid
  • Hants
Re: ceiling light
« Reply #15 on: 26 August 2013, 23:37:53 »
Yep...... :y :y  My monies on the switch, but I would have tried a new basic on/off switch to test.... :D :D
I would have personally shorted the bare wires together with the circuit energised as a test, but I'm a sparks by trade so I know what I can & can't get away with.
I certainly wouldn't advise anyone to do the same in real life though, especially as they needed to ask the question to start with so I decided to err on the side of caution  ;)
Re: ceiling light
« Reply #16 on: 26 August 2013, 23:50:41 »
 :y :y
kevinp58
  • kent
    • 2002 3.2 elite
Re: ceiling light
« Reply #17 on: 26 August 2013, 23:52:57 »
Dimmer switch for sure they have resisters in them that are a pain, and do cause a lot of fires,  :( do yourself a favour revert back to real switch.  :y ;D
AndyRoid
  • Hants
Re: ceiling light
« Reply #18 on: 27 August 2013, 00:55:18 »
That may have been true 30 years ago, but not so now.
The potentiometer (variable resistor) carries a control current in the region of milliamps, the main load is switched by a Triac (same size as a 5p piece, and can easily switch a 1000 W load without stressing).
Re: ceiling light
« Reply #19 on: 27 August 2013, 09:28:24 »
I knew it.. I knew all sparks were a bit nuts ;)
Though I once watched my Dad (also quite happy with electrics - everything from PLCs to Kv was part of his job until recently, but of course, not Part P so when it came to a rewire..  ::) ;D) weld a pair of needle nose pliers together working on a socket .. of course the house, probably 25 years ago, only had fuse wire so nothing went off ;D
Still have the pliers today, we just filed the welded end off...
P.S. Hope you're doing well!
pauls
  • By the sea minehead
    • Bmw x3
Re: ceiling light
« Reply #20 on: 27 August 2013, 12:03:20 »
Just a update. It was the dimmer switch
Re: ceiling light
« Reply #21 on: 27 August 2013, 21:28:23 »
Result......... :y :y
kevinp58
  • kent
    • 2002 3.2 elite
Re: ceiling light
« Reply #22 on: 27 August 2013, 22:37:43 »
 :y :y :y+1
