Author Topic: runaway  (Read 4925 times)
Bob G
  • Gloucester
runaway
« on: 27 August 2013, 15:30:32 »
well sort of off, coming home yesterday on the motorway, pulled into centre lane to overtake, kicked down and suddenly without any input from me it roared away and redlined, then revs drooped and lost power, managed to pull safely to hard shoulder.  On stopping found engine still running and responding to throttle, EML light on though, checked everything and found no obvious fault, back onto motorway and off it went as normal, although a bit rough to start.
This morning started with short run no EML, followed bit longer run no EML parked for 20 minutes came out and since them EML is on.
Not done paper clip test yet, but any ideas of why?
car is F/L 2.0L running on Petrol when it took place
Re: runaway
« Reply #1 on: 27 August 2013, 16:08:51 »
Throttle has stuck open for some reason, the pedal didn't get stuck under the carpet mat did it?
Bob G
  • Gloucester
Re: runaway
« Reply #2 on: 27 August 2013, 16:50:13 »
mark not as far as I was aware but would not account for EML light would it, just checked it again and it is out, all very strange
Re: runaway
« Reply #3 on: 27 August 2013, 17:00:55 »
Does it have cruise control?
The only things that can actuate the throttle on the 2.0 is the throttle cable (i.e. your foot) or the cruise (if fitted), hence I wonder if during kickdown the cable or throttle pedal has stuck
Bob G
  • Gloucester
Re: runaway
« Reply #4 on: 27 August 2013, 17:13:51 »
ah yes see where you are coming from with that one
Bob G
  • Gloucester
Re: runaway
« Reply #5 on: 27 August 2013, 18:21:48 »
well just done the codes and none the wiser, it flashes 10 times, then three then three which I think equates to incorrect RPM signal so what next?
« Last Edit: 27 August 2013, 18:36:30 by Bob G »
Re: runaway
« Reply #6 on: 27 August 2013, 18:40:21 »
And what comes after the 2nd 3?  Also, not that if multiple codes exist, you need to count them all (each one will repeat 3 times)
Bob G
  • Gloucester
Re: runaway
« Reply #7 on: 27 August 2013, 18:51:09 »
ah missed one out I get 10 335 then it loops back to 10 again
Re: runaway
« Reply #8 on: 27 August 2013, 18:55:51 »
And after you've had 3 lots of 0335? (10=0)
Bob G
  • Gloucester
Re: runaway
« Reply #9 on: 27 August 2013, 19:10:03 »
nothing that's all I get just loops round same figures
dbdb
  • west london
  • Tramlining,Trade Club,WIM,my time racing,Linux etc
    • f/l elite 2.6 V6 manual
Re: runaway
« Reply #10 on: 28 August 2013, 02:32:37 »
0335 is Crankshaft Position sensor "A" circuit malfunction
Bob G
  • Gloucester
Re: runaway
« Reply #11 on: 28 August 2013, 09:40:20 »
is that the same as incorrect RPM signal? as that is what the code lists on the maint section
« Last Edit: 28 August 2013, 09:42:39 by Bob G »
Re: runaway
« Reply #12 on: 28 August 2013, 12:07:54 »
Yes and is the correct (and more useful/descriptive) one for the Vx setup
Bob G
  • Gloucester
Re: runaway
« Reply #13 on: 28 August 2013, 13:51:13 »
right so now we know what the code means can someone tell me what needs to be done, out of interest today when using car first off no light not until it got warm has the light come on, only think that I can notice is a very very slight sluggishness on move off apart from that it seems ok.
All advice welcome as I want to sort this.
Re: runaway
« Reply #14 on: 28 August 2013, 14:54:08 »
Its pointing at the crank sensor, behaviour hints at this to (they are more liable to cause issues when hot)
