Pages: [1] 2 3  All   Go Down
Author Topic: autobox slipping  (Read 9334 times)
colv6
  • liverpool
    • 2002 2.6 cd
autobox slipping
« on: 28 August 2013, 20:55:54 »
brothers car, 98 3ltr elite m/f
been off the road for two years (builder runs a van a the daily workhorse)
took it for an mot last saturday flew through one advisor rusty disc's
 on his way home noticed steam from the drivers side, temp guage reading all ok jumped out to check on lifting the bonnet vapour from the rear of the engine left hand side as viewed from the front and a brownish fluid driping from the rear of the engine block.
after a while got back into the car after checking all fluids were ok, headed to my place no warnings on the mid or dash after about half a mile the car was behaving as a manual would with a sliping clutch just reving very little drive in d or 1 2 3 left to stand a while ran perfect again for half a mile then same fault.
at my place papercliped no faults
code reader on transmission reads fault code p0722 -(4) output speed sensor circuit no  signal - not present.
filter removed cleaned and replaced along with new fluid still same problem, code cleared then when retested p0722 code again
any pearls of wisdom gratefully recieved.
1998 3ltr elite (RIP rearended)
Re: autobox slipping
« Reply #1 on: 28 August 2013, 21:56:33 »
Sure you've got the correct amount of atf in (see maint guides) - symptoms are of low atf ;)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #2 on: 28 August 2013, 22:47:59 »
I would say the leak was from the HBV given the location you describe,as for gearbox,as dbug says fluid level :y
other rides
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #3 on: 28 August 2013, 23:13:23 »
Sounds like HBV, maybe soaked the selector switch?
colv6
  • liverpool
    • 2002 2.6 cd
« Reply #4 on: 31 August 2013, 19:58:57 »
after spending the afternoon under the car and folowing mark's guide to the letter still no joy.
same as before after a couple of min's no drive in any gear, it just feels like something has told the box it's in nutural, turn it off give it a second and restart and all is fine as though it has reset it self, then same fault again.
can anyone tell me in plain english what the fault code means,
colv6
  • liverpool
    • 2002 2.6 cd
« Reply #5 on: 31 August 2013, 20:07:04 »
   omegod,
where can i find this switch ?
FERRETMAN1
  • Colchester essex
    • omega elite
« Reply #6 on: 31 August 2013, 20:22:53 »
mine had same prob after being parked up crank sharft seal went flat not realizing went for mot torque converter blew whilst over pit new seal and secondhand torque ok now
colv6
  • liverpool
    • 2002 2.6 cd
« Reply #7 on: 31 August 2013, 20:35:08 »
thanks for the input, might be time to look for a gearbox ?
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #8 on: 01 September 2013, 10:59:44 »
before getting too drastic with gearbox I would try and new GM crank sensor. Replacing atf and filter plus new crank sensor sorted my similar issues 4 years ago.
colv6
  • liverpool
    • 2002 2.6 cd
« Reply #9 on: 01 September 2013, 14:21:19 »
i hear what you are saying but would a duff crank sensor not through up a 19 fault code ?
« Reply #10 on: 01 September 2013, 14:22:41 »
Not always  :y
colv6
  • liverpool
    • 2002 2.6 cd
« Reply #11 on: 01 September 2013, 14:47:02 »
i will go and collect a hbv and crank sensor of omegod who is braking one at the moment, change them and see what happens from there ?
sassanach
  • trowbridge
« Reply #12 on: 01 September 2013, 20:51:46 »
why don't you check/replace the output sensor and wiring at the rear of the box?(delete as appropriate)
colv6
  • liverpool
    • 2002 2.6 cd
« Reply #13 on: 01 September 2013, 22:26:47 »
i take it that is what the fault code is pointing to?  i am on a steep learning curve here, any one got a pic of a autobox and where each part is ?
sassanach
  • trowbridge
« Reply #14 on: 02 September 2013, 15:37:38 »
the output speed sensor is on the tail shaft of the slushbox with a multiplug on it.the chances are that the plug has been broken,i think the boy did this once when he removed his slushbox and forgot to unplug it first.maybe the wires were strained on a previous box removal?
Pages: [1] 2 3  All   Go Up
