Author Topic: Wheel arches  (Read 1323 times)
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
Wheel arches
« on: 29 August 2013, 12:24:46 »
I'm fixing some rust on my rear wheel arches. I've noticed there's a cloth-like tape behind the door, on the arch, which I'll need to replace. Does anyone know what type of tape this is and what it's for. I imagine it's to help stop the door rubbing against the arch?
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
Re: Wheel arches
« Reply #1 on: 30 August 2013, 00:55:51 »
Its understand it's called an protector strip, and I believe it is where the rubber seal of the door contacts. As there is usually a lot of grit on that rubber, I presume its to protect the paintwork.
VX part nos are 90511361 (RH), and 90511360 (LH).
In the past, when I have been repairing wheelarches, I have successfully removed them using a hot air gun (gently), and following the repair, reapplied them with automotive carpet spray adhesive. Just be careful they don't stretch too much when removing them.
Re: Wheel arches
« Reply #2 on: 30 August 2013, 03:53:44 »
Wot 'e sed :P not the best value new part, but readily available from VX, about £8 each last time I bought one (three years ago iirc) :-\
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
Re: Wheel arches
« Reply #3 on: 30 August 2013, 12:27:52 »
Do you think a hair dryer would be hot enough to loosen the glue holding the strip?
