Pages: [1] 2 3  All   Go Down
Author Topic: 3.2 Engine  (Read 9585 times)
3.2 Engine
« on: 02 September 2013, 21:37:25 »
How much is a 3.2 engine worth with ECU  :-\ Mates rates of course  ::) ;D
Re: 3.2 Engine
« Reply #1 on: 02 September 2013, 22:46:49 »
More than your Vectra ;D
Re: 3.2 Engine
« Reply #2 on: 02 September 2013, 22:54:22 »
 Aye but it wont fit , well maybe it will  :-\ ;D I recon about £200-250  :-\
Re: 3.2 Engine
« Reply #3 on: 02 September 2013, 22:58:34 »
Should have bought a 2.6 then ::) straight swap 8)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: 3.2 Engine
« Reply #4 on: 02 September 2013, 23:03:16 »
Can't find any Omega 3.2 engines on eBay but there are a few Vectra C ones like this.
Link
Re: 3.2 Engine
« Reply #5 on: 02 September 2013, 23:05:21 »
Yeah but not for my superior vectra  :P 2.0 uses enough petrol thanks  ::) ;D
Re: 3.2 Engine
« Reply #6 on: 02 September 2013, 23:09:35 »
Link
Ah vectra C  :( Still , i think thats a bit steep but what do i know  ;D
No mention of ECU's with these engines  :(
Re: 3.2 Engine
« Reply #7 on: 03 September 2013, 00:17:13 »
Link
Ive had a 3.2 Omega engine for sale on here for the last 6 weeks.  ::) ;)
Also have the ECU etc. with it.
« Last Edit: 03 September 2013, 00:31:36 by Albitz »
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: 3.2 Engine
« Reply #8 on: 03 September 2013, 00:36:18 »
Link
Thought it had sold  :-[
...Your in luck then by looks of it Mr. Emd  :y
Now C'mon what you got planned for it ? ::)
Re: 3.2 Engine
« Reply #9 on: 03 September 2013, 00:43:45 »
It was "sold",but the bloke never turned up to collect / pay,so now its not sold. :y ;D
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: 3.2 Engine
« Reply #10 on: 03 September 2013, 01:04:39 »
Typical, Theres always someone or another ready and waiting to waste ones time.
Would imagine a 3.2 block would weigh a fair amount, Couldn't have been easy to get it out without damaging it  :o
Biggest engine I've transplanted was a 1.7D Endura ford engine with a tripod type device full of rust and holes  ;D
Re: 3.2 Engine
« Reply #11 on: 03 September 2013, 01:07:34 »
Didn't do any damage to the engine.Did plenty to myself though. ;D ;D
Re: 3.2 Engine
« Reply #12 on: 03 September 2013, 10:54:27 »
A TD comes out fairly easy, and thats longer and heavier.  I would expect a V6 to be fairly straightforward to remove.
Bloody hard work doing in on your own though, I imagine.
Re: 3.2 Engine
« Reply #13 on: 03 September 2013, 11:45:27 »
Apart from doing it by myself,the big problem was that the manifold to downpipe nuts wouldn't come off no matter what I tried.
In the end I unbolted the manifolds from the heads,which cost a fair amount of skin & blood.Particularily the n/s which had the sharp ends of all the brake pipes,where the ABS pump had been removed. Brake fluid in cuts don't half sting ;D
Then had to try to remove the engine & box past the manifolds.This proved  exhausting and impossible for several hours. Eventually,I managed to remove one of the cats and manifold down under the car out of the way,and then the engine / box came out - just. Cant remember the last time I was that tired/sore/filthy from head to toe. The cuts & grazes are starting to heal now ;D
« Last Edit: 03 September 2013, 11:48:02 by Albitz »
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
Re: 3.2 Engine
« Reply #14 on: 03 September 2013, 13:22:38 »
I had this problem when I did my head gaskets, where 3 nuts came undone and the last nearside one wouldn't.  >:( The nut rounded in the end where I was trying so hard. So I ended up grinding each side of the nut almost through to the thread and it then came undone. The only way I could get a grinder of sufficient power was a heavy duty craft one, with a flexible shaft and small grindstone. I then had to attach a piece wood to the end of the flexible shaft, due to the depth to the nut and use that for leverage and gradually grind away the nut. I rarely swear, but the Omega and its awkness to work on has me doing that all too often.  :o :o :o :o :o
Pages: [1] 2 3  All   Go Up
