Pages: 1 [2] 3  All   Go Down
Author Topic: 3.2 Engine  (Read 9587 times)
Re: 3.2 Engine
« Reply #15 on: 03 September 2013, 13:48:21 »
Apart from doing it by myself,the big problem was that the manifold to downpipe nuts wouldn't come off no matter what I tried.
In the end I unbolted the manifolds from the heads,which cost a fair amount of skin & blood.Particularily the n/s which had the sharp ends of all the brake pipes,where the ABS pump had been removed. Brake fluid in cuts don't half sting ;D
Then had to try to remove the engine & box past the manifolds.This proved  exhausting and impossible for several hours. Eventually,I managed to remove one of the cats and manifold down under the car out of the way,and then the engine / box came out - just. Cant remember the last time I was that tired/sore/filthy from head to toe. The cuts & grazes are starting to heal now ;D
 :o :o
Now C'mon what you got planned for it ?
Nothing  ;D as it wrong wheel drive a V8 is out of the question  :-\ ::) ;D It was just a general question to get some sort of idea what these V6 lumps fetch  :-\ Seems they are becoming quite popular for coffee tables  :( V6 coffee tables are fetching big money  ::)
Re: 3.2 Engine
« Reply #16 on: 03 September 2013, 14:33:43 »
Grow a pair and man up :P
Northstar V8 will drop straight in, and it's wwd :y
4.4 V8 Vectra B anyone ;D
Re: 3.2 Engine
« Reply #17 on: 03 September 2013, 14:46:57 »
 :o ::) :-\ ??? :-\
Well no need when another omega is on the cards  :P :P Vectra B will be put into storage for 20 yrs then put on egay  :P
serek
  • huntingdon
    • 3.2 mv6
Re: 3.2 Engine
« Reply #18 on: 03 September 2013, 18:05:19 »
How much is a 3.2 engine worth with ECU  :-\ Mates rates of course  ::) ;D
mate rates maybe £100 other way you looking from £350 up really
why you need ecu with it any way??
Re: 3.2 Engine
« Reply #19 on: 03 September 2013, 18:37:46 »
Well say i have a 2.5 or 3.0 would i need the 3.2 ecu to go with the 3.2 engine or am i talking rubbish  ::) :-\ ;D
Re: 3.2 Engine
« Reply #20 on: 03 September 2013, 18:45:52 »
Yes you would its a different type of ecu from the 2.5/3.0. :y
Also need keychip and transponder with the ECU. ;)
Re: 3.2 Engine
« Reply #21 on: 03 September 2013, 18:52:54 »
Re: 3.2 Engine
« Reply #22 on: 03 September 2013, 19:04:49 »
Depends if you want to use the 2.5 electrical stuff, and throttle bottle.
martin42
Re: 3.2 Engine
« Reply #23 on: 03 September 2013, 21:50:44 »
Would it be to do with this
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: 3.2 Engine
« Reply #24 on: 03 September 2013, 22:05:07 »
I wouldn't imagine that had ended well :o
other rides
Re: 3.2 Engine
« Reply #25 on: 03 September 2013, 22:12:42 »
 :-X :-X :-X
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: 3.2 Engine
« Reply #26 on: 06 September 2013, 10:25:41 »
Got complete 3.0L sitting here,  :)
Hoof'land storeman.
Re: 3.2 Engine
« Reply #27 on: 06 September 2013, 15:09:11 »
Did you hear that webby
serek
  • huntingdon
    • 3.2 mv6
Re: 3.2 Engine
« Reply #28 on: 07 September 2013, 22:50:11 »
so you need for Vectra V6?
you need just bare engine and wiring loom of 2.5/3.0
I have Vectra b 3.2 v6 here if you fancy ride
biggriffin
Re: 3.2 Engine
« Reply #29 on: 08 September 2013, 07:29:38 »
Webby you know you want a 3.0L, its just sitting here waiting for a new home, like in your 2.5. :y
Hoof'land storeman.
Pages: 1 [2] 3  All   Go Up
Page created in 0.741 seconds with 20 queries.
