Pages: [1] 2 3 4 5 6   Go Down
Author Topic: Camshaft Removal  (Read 19447 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Camshaft Removal
« on: 03 September 2013, 09:15:36 »
Hi guys,
Once i've got car free of cam covers and timing belt off etc whats the procedure for removing the camshafts IF i cant get the sprockets undone?
i remember on Ralf they were un-removable as they must have been out before as the heads of the torx bolts were stripped, thus making it impossible to get them out.
Thanks.
RIP Paul Lovejoy
Re: Camshaft Removal
« Reply #1 on: 03 September 2013, 11:54:12 »
Don't see why you would need to remove the sprockets  :-\ After the belt is off,undo all the bolts on the cam caps (keeping the caps in the correct order is very important) then just withdraw the cams from the heads.
Webby the Bear
  • Northampton
« Reply #2 on: 03 September 2013, 11:58:06 »
Thats exactly what i did on Ralf mate...... but i was concerned that would i ruin the canshaft oil seal thingy? or would it simply withdraw from the rear cam cover as i did with ralf?
cheers for the response mate  :y :y
RIP Paul Lovejoy
« Reply #3 on: 03 September 2013, 12:00:46 »
Remember, engine in "safe" position (60 degrees BTDC on a V6) before playing with camshafts.
Webby the Bear
  • Northampton
« Reply #4 on: 03 September 2013, 12:03:40 »
Thanks TB.  :y
RIP Paul Lovejoy
« Reply #5 on: 03 September 2013, 12:03:52 »
Sorry Webby,youve lost me now. ;D
Webby the Bear
  • Northampton
« Reply #6 on: 03 September 2013, 12:17:21 »
 ;D ;D ;D sorry boyo.
what i meant was this.....
you know the camshaft sprocket.... well behind that its connected to the rear timing belt cover. thats why they say to take the sprockets off.
BUT.
I'm thinking that you undo the cam shaft shells..... then pull the camshaft including sprocket forward.
is this correct?.....or have i lost you again  ;D ;D
RIP Paul Lovejoy
« Reply #7 on: 03 September 2013, 12:21:40 »
Correct. :y............................iirc. :-\ ??? ;D
Webby the Bear
  • Northampton
« Reply #8 on: 03 September 2013, 12:32:18 »
 ;D ;D ;D
cheers mate. are there bolts securing it in or will it just pull out> if there are bolts i should be able to get to them through the holes in the sprocket, right?  :-\
RIP Paul Lovejoy
« Reply #9 on: 03 September 2013, 13:52:40 »
Cant remember.Havent done one for nearly a year. :-[ ;D
viper357
  • Worthing
    • 2001 3.2 Elite
« Reply #10 on: 03 September 2013, 16:15:20 »
SOunds like a hell of a job, post some pics :p
Dean
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #11 on: 03 September 2013, 17:11:41 »
BUT.
I reckon you will get them out ok but theres no way you can re-fit them and get the oils seals seated properly without getting the pulleys off :-\
other rides
Webby the Bear
  • Northampton
« Reply #12 on: 03 September 2013, 17:35:09 »
BUT.
youre probably right mate... it certainly doesn't mention in any guide that you can remove and refit without taking the sprockets off.... lucky I got a 1/2" T55 socket for my breaker bar.  ::) :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #13 on: 03 September 2013, 17:35:38 »
keep your eyes peeled.... theres a big thread coming soon  ::) :y :y :y
RIP Paul Lovejoy
henryd
  • west cornwall
« Reply #14 on: 03 September 2013, 18:29:01 »
You going to 3.0 cams or similar ??? :D
other rides
Pages: [1] 2 3 4 5 6   Go Up
