Pages: 1 [2] 3 4 5 6   Go Down
Author Topic: Camshaft Removal  (Read 19445 times)
Re: Camshaft Removal
« Reply #15 on: 03 September 2013, 18:31:12 »
SOunds like a hell of a job, post some pics :p
keep your eyes peeled.... theres a big thread coming soon  ::) :y :y :y
You going to 3.0 cams or similar ??? :D
Would be wrong not to  ;)
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #16 on: 03 September 2013, 19:55:44 »
I don't recall the sprocket bolts being that tight to be honest, now head bolts..... :o :o :o :o hernia tight
  • Auckland
    • Mazda MPV
« Reply #17 on: 03 September 2013, 20:11:07 »
IIRC Haynes lists them as being stretch bolts that should be replaced every time the sprockets are taken off (not that anyone I know has done so ::))
I would drill through the bolt heads to remove them and fit new ones on assembly (if I was feeling really brave I would use some second hand ones..........)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #18 on: 03 September 2013, 21:02:12 »
Quite a productive evening...
Sprockets came off piece of piece  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #19 on: 03 September 2013, 21:02:59 »
piece of piss even  ::)
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #20 on: 04 September 2013, 08:58:34 »
Do the sprockets only go back on one way??? how do I get them lined up correctly on refitting...
RIP Paul Lovejoy
« Reply #21 on: 04 September 2013, 09:09:56 »
Each sprocket has numbers on it, make sure that number on the sprocket corresponds to the keyway on the relevant camshaft, eg far drivers side number one, and so on. 246 bank sprockets have a longer shaft on them :y
Webby the Bear
  • Northampton
« Reply #22 on: 04 September 2013, 13:52:42 »
Thanks James.  :y
you know when you've taken the sprockets off.... do you mean that where it says ''1'' for example that goes closest to the little shiny metal notch sticking out of the cam seal? sorry for being thick  :-[
RIP Paul Lovejoy
« Reply #23 on: 04 September 2013, 15:22:16 »
Thanks James.  :y
Lets take drivers side exhaust cam for argument sake. This is no1. Where it says 1 on the pulley, fit the pulley so that the key (bit that sticks out the front if the camshaft) goes in the notch on the pulley closest to where the no1 is stamped.
Typing on my iPhone , does that make sense?
Webby the Bear
  • Northampton
« Reply #24 on: 04 September 2013, 17:19:21 »
Thanks James.  :y
yep perfectly understood thanks james  :y :y :y :y :y
RIP Paul Lovejoy
  • Auckland
    • Mazda MPV
« Reply #25 on: 04 September 2013, 19:51:24 »
Ah, not Ralf  :-\. I'm guessing the bolt heads were in 'as new' condition then :y
« Reply #26 on: 05 September 2013, 15:17:49 »
Have you replaced the piston rings yet mate  :-\
martin42
« Reply #27 on: 05 September 2013, 19:57:25 »
Pistons are fine  :D
« Reply #28 on: 05 September 2013, 20:35:20 »
martin42
« Reply #29 on: 05 September 2013, 20:36:16 »
But the valves,bent to hell lol
Pages: 1 [2] 3 4 5 6   Go Up
