Author Topic: memory seats to a MV6  (Read 2427 times)
Big_Al
« on: 06 September 2013, 07:41:30 »
I am thinking of changing seats to Elite leather &  just looked at the guide on fitting elite seats to other models.
If the minor wiring adaption is carried out as shown will this allow  the memory system work ? :-\ :-\
or is Tech 2 required to programme ? :-\
TIA    Al :y
Re: memory seats to a MV6
« Reply #1 on: 06 September 2013, 12:59:15 »
TIA    Al :y
Yes.
No.   :y
« Reply #2 on: 07 September 2013, 09:42:26 »
Im assuming though that the wiring & plugs to MV6 seats will be the same setup as a basic (CD) spec Omega. Perhaps someone could confirm ?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #3 on: 07 September 2013, 11:10:48 »
Have Had FL 2000 MV6 leather in a FL 2000 CD before no issues.  :y
« Reply #4 on: 07 September 2013, 11:15:25 »
Electrical connectors a straight swap Chris ?
zirk
  • Epping Forest
« Reply #5 on: 07 September 2013, 11:25:07 »
From memory yes Albs, a few years back now, its was a Car I got from CraigA (Watford Member, another 'Garage said HG Fail' when it wasn't), He had MV6 Leather fitted to his 2.0 LPG CD, I put some CD Seats back in before I shifted the car, fairly sure it was a straight swop.
« Reply #6 on: 07 September 2013, 11:34:49 »
Cheers. :y
Big_Al
« Reply #7 on: 07 September 2013, 20:18:32 »
This is gonna be FL  Elite leather seats to   FL  MV6 though  :-\ :-\  any probs gonna occur ? :-\ :-\
zirk
  • Epping Forest
« Reply #8 on: 07 September 2013, 21:26:02 »
I did wonder about that when I read the post title, where did the CD bit come from then?, or am I guessing Albs has done the Elite to CD swop in the past and wanted to confirm that MV6 would be the same deal? Should be ok though, longer seat bolts on the Elite so grab them, plus all the rear wiring and stuff if you want the rears to heat up.  :y
« Last Edit: 07 September 2013, 21:27:48 by zirk »
Big_Al
« Reply #9 on: 07 September 2013, 21:42:38 »
Albs . . .  you reading this  ;D ;D ;D
« Reply #10 on: 07 September 2013, 21:56:12 »
Yes mate.Bolts,switches,relays looms etc. all included. :y
