Author Topic: wobbel  (Read 1471 times)
chappa
  • sunderland
    • omega elite v6
wobbel
« on: 08 September 2013, 19:54:57 »
hi there ive got another problem with the omega when in driving at 40/50mph and brake i get a horrible wobbel/vibration through the steering wheel could that b the disks or something worse cheers
Re: wobbel
« Reply #1 on: 08 September 2013, 20:22:42 »
Discs or wishbone bushes fubar'd  ;) ;)
Re: wobbel
« Reply #2 on: 08 September 2013, 20:31:49 »
As above - if discs use Vx genuine (sold as set discs + pads around £100)
cnj
  • ludgershall
    • 2.2 Manual CD(51 plate)
Re: wobbel
« Reply #3 on: 09 September 2013, 05:57:36 »
suspect warped discs !
chrisgixer
Re: wobbel
« Reply #4 on: 09 September 2013, 07:18:27 »
Inspection required.
Worn/warped discs is quite harsh and in time with wheel speed, where as wishbone bush wear is a softer feel at a more random frequency, bit like a tank slapper on a bike, and isn't always present. Where as a disc issue is there EVERY time brakes are applied.
Depending on the accuracy of the description though, I guess wheel balance might be relevant, although at that speed range, I'd bet on bushes. (Only £1 mind ;) )
Re: wobbel
« Reply #5 on: 09 September 2013, 09:19:49 »
What Gixer says.  I'm suffering the same currently  :-[
Re: wobbel
« Reply #6 on: 09 September 2013, 14:15:00 »
Tend to agree - normally wheel wobble around 50mph is suspension/steering related
