Author Topic: Power Steering Pump  (Read 1428 times)
    • 530D M Sport, 330i Coupe
Power Steering Pump
« on: 09 September 2013, 11:05:48 »
Would anyone with EPC be able to confirm or deny if the PS Pump on a 52 2.2DTi Elite is the same as an 03 2.6 V6 Elite.
Both Vehicles have Servotronic.
Currently too wet to be wrestling under bonnet and my EPC is no worky.
Re: Power Steering Pump
« Reply #1 on: 09 September 2013, 12:42:53 »
guess not...
X20DTH and Y22DTH:
   POWER STEERING PUMP (CONTD.) - X20DTH,Y22DTH ENGINES
    1 90573827 9 48 084 PUMP, ASSY., POWER STEERING AND AIR CONDITIONING COMPRESSOR BRACKET (EXCHANGE PART 93175573 OPEL, R1700025 VAUXHALL)    1
    2 90502551 59 48 195 -HUB, PULLEY (EXCHANGE PART 93175567 OPEL, R1700019 VAUXHALL) Y22DTH   1
    3X 9156917 9 48 380 REPAIR KIT, POWER STEERING PUMP (ZF)    1
    1 93175573 59 48 038 PUMP, ASSY., POWER STEERING AND AIR CONDITIONING COMPRESSOR BRACKET, EXCHANGE (CORE RETURN NO. 95 09 097) (EXCEPT VAUXHALL)    1
    1 R1700025  PUMP, ASSY., POWER STEERING AND AIR CONDITIONING COMPRESSOR BRACKET, EXCHANGE (FOR VAUXHALL) (CORE RETURN NO. C1700025)    1
V6
  3 90467000 9 48 055 PUMP, ASSY., WITH PULLEY (EXCHANGE PART 93175571 OPEL, R1700023 VAUXHALL) X25XE, X30XE (C)  -T1999999 1
    3 93175571 59 48 036 PUMP, ASSY., WITH PULLEY, EXCHANGE (CORE RETURN NO. 95 09 095) (EXCEPT VAUXHALL) X25XE, X30XE (C)  -T1999999 1
    3 R1700023  PUMP, ASSY., WITH PULLEY, EXCHANGE (FOR VAUXHALL) X25XE, X30XE (C)  -T1999999 1
    3 (90531698) (9 48 072) PUMP, ASSY., WITH PULLEY (NLS.- USE 90573227) X25XE, X30XE (C) V1000001- W1199912 1
    4 (90573227) (9 48 086) PUMP, ASSY., WITH PULLEY, LHD (DELPHI) (NLS.- USE 24436787 9 48 098 AND SUPPLY 24436399, 24445102)  (C) W1199913- 21031572 1
    4 (90573227) (9 48 086) PUMP, ASSY., WITH PULLEY, RHD (DELPHI) (NLS.- USE 24436787 9 48 098 AND SUPPLY 24436399, 24425996, 24445103, 24426002)  (C) W1199913- 21031572 1
    4 24436787 9 48 098 PUMP, ASSY., WITH PULLEY (IDENT 6787) (ZF) (EXCHANGE PART 93175572 OPEL, R1700024 VAUXHALL)  (C) 21031573-  1
    5 90409788 9 50 317 -PULLEY, PUMP    1
    6 90410959 9 50 301 -HUB, PULLEY    1
    7 90528953 9 49 918 -SCREW, HEX.HD., PULLEY TO PUMP, M8 X 12 X25XE, X30XE   3
    8 (90500050) (9 51 912) -SHACKLE, POWER STEERING PUMP AND CHECK VALVE BRACKET (NLS.- USE 90573228) X25XE, X30XE (C)  -W1199912 1
    9 90573228 9 51 952 -SHACKLE, POWER STEERING PUMP AND CHECK VALVE BRACKET  (C) W1199913-  1
    4 93175572 59 48 037 PUMP, ASSY., WITH PULLEY, EXCHANGE (CORE RETURN NO. 95 09 096) (EXCEPT VAUXHALL)  (C) 21031573-  1
    4 R1700024  PUMP, ASSY., WITH PULLEY, EXCHANGE (FOR VAUXHALL) (CORE RETURN NO. C1700024)  (C) 21031573-  1
    10 11097651 20 00 911 SCREW, M8 X 18, SHACKLE AND POWER STEERING PUMP TO SUPPORT    2
    10 11097651 20 00 911 SCREW, M8 X 18, SHACKLE TO POWER STEERING PUMP    2
    11 11097441 20 02 613 SCREW, M8 X 35, POWER STEERING PUMP TO SUPPORT X25XE, X30XE   3
    20 90499208 9 50 410 SUPPORT, POWER STEERING PUMP (IDENT PR) X25XE, X30XE (C)  -T1999999 1
    Note: EXC.AIR CONDITIONING
    21 90531716 9 50 453 SUPPORT, POWER STEERING PUMP (IDENT BJ)  (C) V1000001-  1
    22 90531707 18 54 346 SUPPORT, AIR CONDITIONING COMPRESSOR AND POWER STEERING PUMP  (C) V1000001-  1
    Note: USED WITH AIR CONDITIONING
    23 (11093611) (20 05 200) SCREW, HEX.HD., PUMP TO SUPPORT BRACKET (NLS.- USE 11093612) X25XE, X30XE (C)  -T1999999 1
    24 11093801 20 05 215 SCREW, HEX.HD., PUMP TO SUPPORT BRACKET X25XE, X30XE (C)  -T1999999 1
    25 11098031 20 05 634 SCREW, TORX, M8 X 80, PUMP TO SUPPORT BRACKET  (C) V1000001-  2
    26 11094041 20 05 474 SCREW, TORX, M10 X 79, SUPPORT TO CYLINDER BLOCK    3
    27 11067237 20 66 218 NUT, HEX., M10 X25XE, X30XE   3
« Reply #2 on: 09 September 2013, 13:53:16 »
Oh well, worth checking.
Not sure if I should fit a 2nd hand unit or send the existing unit away to be refurbished.
Page created in 0.049 seconds with 21 queries.
