Author Topic: Door handle left in hand  (Read 1823 times)
Muroman
  • Finland
  • Cars for life
    • Vectra -02
« on: 09 September 2013, 15:40:20 »
So, I got to my car from work and tried to open door but my door handle broke and now I got to open the door from passenger side...
So the questions are how much I need to take things off from the door? Does anyone have pictures off the handle mechanism?
I don't have carage in my use right now so when I start the project I probably need to finish it at same day if I need to take the lock off?
Is it possible to only change the handle?
-Mika
Driving: Vectra - 2002 - 2.2 "GTS" - Manual
Old: Omega - 1999 - MV6 - Automatic
Old: Omega - 1995 - MV6 - Manual
Re: Door handle left in hand
« Reply #1 on: 09 September 2013, 15:51:23 »
Too many Weetabix?  ;)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #2 on: 09 September 2013, 16:00:08 »
Door card off then simple job I think others will confirm
« Reply #3 on: 09 September 2013, 16:41:16 »
Yes and you can swap the original key barrel over.
« Reply #4 on: 09 September 2013, 18:17:57 »
-Mika
I'm sure there are no pictures of this, but when you get the door card off & the plastic membrane, you'll see that it is all quite easy & straight forward.  :y :y You just need to find a handle of the correct colour.  ;)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #5 on: 09 September 2013, 18:21:47 »
Happened to me a few years back when the door frame was frosted up and I was being inpatient, got fed up keep climbing over passenger side, so ended end cable tie'ing some cable to the inside handle to the back of the door so I could open it from the drivers rear door.  Down side to that was it give me an excuse not to fix for a week or two.
As said Door Card off and replace the Plastic bits.  :y
« Reply #6 on: 09 September 2013, 18:32:52 »
..... and replace the Plastic bits.  :y
 ??? Plastic?  ??? It was an alloy section of the handle's hinge that broke on mine
Muroman
  • Finland
  • Cars for life
    • Vectra -02
« Reply #7 on: 09 September 2013, 18:43:19 »
May be due to Weetabix :D
But ye I think I start from car scrap yards trying to get hold of same color handle :) Tomorrow :)
And here's picture of the broken part and I think it's plastic.
-Mika
