Pages: 1 2 [3]  All   Go Down
Author Topic: Is my 'comfort' modul working fine?  (Read 14750 times)
  • Auckland
    • Mazda MPV
Re: Is my 'comfort' modul working fine?
« Reply #30 on: 16 September 2013, 18:23:59 »
And fitted to all UK spec cars post 1996, not sure about 94 and 95 cars
My 94 2.5 CD saloon had it. :y
Bob G
  • Gloucester
« Reply #31 on: 16 September 2013, 20:04:09 »
My 2000 GLS has it :y
« Reply #32 on: 18 September 2013, 10:18:55 »
All the ex plods I have driven/owned have it :y
fazekasa
  • Hungary
    • Opel Omega B2 2.5TD 2000
« Reply #33 on: 18 September 2013, 11:10:54 »
Fuses checked, all is ok!
So, you checked the fuses, found a duff one & now all is OK or ............ checked fuses, all were OK & the windows still don't work off the fob/lock  :-\  :-\
So I have checked them and all were ok, hadn't need to change anyone of them.
Andrew
"Thay say jump, you say how high..."
« Reply #34 on: 18 September 2013, 11:12:34 »
and are your windows now closing via the fob?  :-\
fazekasa
  • Hungary
« Reply #35 on: 18 September 2013, 11:16:29 »
Do the windows go up via the switch on their own ie press the switch, let go & the window carries on till it's closed or hits an obstruction? If yes, then I don't know, but if not, the windows need resetting by closing each window & then hold the witch till you hear a click in the door. This should restore the function by either fob or holding the key in the lock position till they're closed. If you have a sunroof, it should close that too.  :y
My bet is that this is the problem.  fazekasa are you certain the windows close all the way when you pull up the window switch briefly and let go?  Or do you have to hold the switch up all the time until they are closed (safe mode)? If so, simple fix as mentioned. The windows will not close remotely if they are in safe mode.
Is it possible to close windows with the window switch and let go. But not possible to close them from outside from the key.
Andrew
fazekasa
  • Hungary
« Reply #36 on: 18 September 2013, 11:17:39 »
Sorry, what is fob?
Andrew
« Reply #37 on: 18 September 2013, 11:21:12 »
Buttons on the key :y
If the one touch feature works on the window switches, they should close with the key buttons :-\
Does the remote locking work?
fazekasa
  • Hungary
« Reply #38 on: 18 September 2013, 11:24:58 »
Yes, its working, I can lock my car with it, but not possible to close the windows with it.  :'(
That is my problem. It could be some differences between my komfort modul and other moduls.
One of my friend Omega's has the same problem.
Andrew
fazekasa
  • Hungary
« Reply #39 on: 18 September 2013, 11:30:59 »
http://youtube.com/watch?v=uEagptZUXoU
 Didn't even know about this....MFL
This is the function that I'm missing.
Andrew
fazekasa
  • Hungary
« Reply #40 on: 18 September 2013, 11:51:07 »
No.  :-\
Andrew
SPD
  • Bulgaria
« Reply #41 on: 19 September 2013, 21:30:34 »
I had the same problem on my 2002 2.5 DTI. The problem was with one wire which was disconnected. You must check your wires. Possibly you will receive error 00018 - comfort module/sunroof low voltage when you use "My Naff Code Reader". Try to locate this wire and fix it. It works for me.
fazekasa
  • Hungary
« Reply #42 on: 23 September 2013, 14:25:24 »
What is "My Naff Code Reader"  ???
Last weekend we have checked the car with a code reader, nothing similar.
Andrew
Pages: 1 2 [3]  All   Go Up
