Oxfordshire - Cambelts
Started by joshwyatt, 18 September 2013, 11:30:40
Darth Loo-knee
Its a bit of a pain... I have a crank tool  ;)
There are bolts inside the sump that need undoing.......I am trying to remember but doesnt the dipstick  have a clip in the sump to hold it in.......
Darth Loo-knee
Where the oil pump fits to the block you use sealant..... like I said not seen any actually leak from there. Ask The Master to see if he has....if not I doubt it will be that as he and I have seen quite a few between us
Quote from: Darth Groomer, Bum Improver on 18 September 2013, 21:04:06
I asked at Newent, but he seemed to give the impression it was unlikely.  A localish member to me, jb, who has had a fair few Omegas, has seen leaks from there.
Any other ideas where it could leak? Reckon its that side of the block, as it initially appears on the top of the sump, between block and compressor.
Mr Haynes says nowt about the compressor, simply that the alternator needs slackening in order to swing it to one side :y
Aloy plate between bottom of block and top of the sump ? My p/fl sprung a leak from there,at which point I sold it.
Quote from: Albitz on 18 September 2013, 21:14:48
As in the upper sump? DLK resealed that for me a while back....
Darth Loo-knee
Lets do it then. I assume your oil pump is ok still, so just a atter of removing it, clean up then reseal.... cambelt needs to come off, sump, sump casting....oil pump slides forwards when all the bolts are removed
Darth Loo-knee
Just like that ;D
Be a good days work I tell ya that ::)
Quote from: Darth Groomer, Bum Improver on 18 September 2013, 21:16:24
I did suspect as much when we where tryingfailing to remove the dipstick at Wycombe, but TB was less than convinced ::)
Quote from: Darth Groomer, Bum Improver on 18 September 2013, 21:18:01
Just like that ;D
I'll repeat that when you're swearing and cursing it ;D
Darth Loo-knee
Quote from: TheBoy on 18 September 2013, 21:25:43
Just like that ;D
Swearing? Never! I am a new man  ;D
Just like that ;D
;D
If it is that seal that is leaking, the pump should just fall off ::)
joshwyatt
So, when do we want to do this?
Darth Loo-knee
Quote from: ex taxi al on 18 September 2013, 21:32:44
Just like that ;D
;D
I will watch you then Al ;D
Darth Loo-knee
Quote from: joshwyatt on 18 September 2013, 21:34:16
Do what, Jammies car? I don't even like him.... would never talk too him either ;D ;D ;D
