Pages: 1 [2] 3  All   Go Down
Author Topic: Small coolant drip - HELP..... 59k miles !!!  (Read 8893 times)
Re: Small coolant drip - HELP..... 59k miles !!!
« Reply #15 on: 19 September 2013, 21:43:01 »
Are you sure it is coolant and not air-con gas thats had green dye put in?
DrAndyB
  • Neston / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« Reply #16 on: 19 September 2013, 22:07:25 »
Pasting the pics has beaten me :-(
dbdb
  • west london
  • Tramlining,Trade Club,WIM,my time racing,Linux etc
    • f/l elite 2.6 V6 manual
« Reply #17 on: 19 September 2013, 23:01:37 »
Just been for a lay down under the car as it's dripping now;-)
Coolant is definitely Green.
But is your coolant in your header tank green?  Normally it would be either blue or red.  Blue could look a little green perhaps but true green is much more likely to be the air con dye as mentioned.  If your header tank coolant is blue or red and the drips are green then they are not coolant.
DrAndyB
  • Neston / Cheshire
« Reply #18 on: 19 September 2013, 23:10:45 »
Thanks to all.  I shall double check coolant colour in header tomorrow when light and report back.
DrAndyB
  • Neston / Cheshire
« Reply #19 on: 20 September 2013, 07:59:36 »
Not checked coolant colour yet (later when get home  :))
HOWEVER
I noticed when looking at the HBV again that there is small wire (spade connector on the with black plastic shrowd) not connected to anything.
Plastic shrowd has a small chip on it, but should this be connected to anything ?
Have a knocked it when feeling  :( the HBV
Is there any pics of the back of the engine I could perhaps see to ascertain where it may plug onto (I can't feel an obvious terminal for it to plug back onto)
Cheers,
Andy,
DrAndyB
  • Neston / Cheshire
« Reply #20 on: 20 September 2013, 08:03:05 »
Sorry - The spade connector is sitting on the end of a single wire, originating from the back NS behind all the pipes at back, and is sitting near the HBV looking at me all homeless with nothing connected to it ?
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #21 on: 20 September 2013, 09:23:39 »
Sounds like coolant temperature sensor is not connected - does the temperature gauge needle work in your car?
Does it look like the pic in the link?
http://www.omegaowners.com/forum/index.php?topic=116572.30
« Last Edit: 20 September 2013, 09:25:38 by Radar »
DrAndyB
  • Neston / Cheshire
« Reply #22 on: 20 September 2013, 09:35:15 »
Temp guage did work, but not ran engine since I had a "feel around back" of the engine  :D
Thanks for the pic - I'll have another feel later now I see where it may have come from :-)
amba
  • Medway towns
    • German V6
« Reply #23 on: 20 September 2013, 10:19:46 »
As advised ,only small wire with spade connector at back of engine is for the temp sender unit.If it wasnt a good tight fit you can easily disturb it poking around the hbv area.
Wiull require the plenum chamber to be removed to be able to get at it properly to replace..would also be wise just squashing the spade terminal abit to ensure it is then a good tight fit incase you dislodge it again.
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #24 on: 20 September 2013, 13:23:48 »
Can be done without taking off plenum
SMD
  • London
    • :( nowt
« Reply #25 on: 21 September 2013, 07:52:47 »
DrAndyB,
I have exactly the same problem, in the same area you describe to the T. Checked the HBV with different heat setting and bone dry. I know mine is coolant
I have not identified the source yet so will keep an eye on this thread
DrAndyB
  • Neston / Cheshire
All fixed - Re: Small coolant drip - HELP..... 59k miles !!!
« Reply #26 on: 06 October 2013, 18:22:00 »
Hi all,
Just a quick report back that it was the Oil cooler plate  >:(
A BIG thanks to Daz for sorting it out  :y  :y  :y (and cambelt, water pump and plugs change  :D - original plugs on 57k mls  :y engine whispers and sings like a good-en now - well pleased  ;D)
Small weep from cooler plate seal noticed after plenum off and engine cooled a little.  It then tracked down either side towards the back of the block to then drip and run down either side of bell housing and drip off the two bolts on the bottom of gearbox.  Never dripped when hot as was clearly evaporating before it could go anywhere and when completely cooled things obviously expanded and contracted back and assume water pressure then dropped back down.
Thanks to all for advice.
Andy.
« Reply #27 on: 06 October 2013, 18:33:47 »
All sorted then, good ol' Dazzle :)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: All fixed - Re: Small coolant drip - HELP..... 59k miles !!!
« Reply #28 on: 07 October 2013, 12:21:14 »
Hi all,
Andy.
Glad its all sorted  :y
SMD
  • London
    • :( nowt
« Reply #29 on: 28 October 2013, 20:04:43 »
This is probably what's causing mine. Is it in plain view to see with only the plenum off? What parts are needed and is it a easy DIY job?
Thanks and sorry for bumping and old thread
Pages: 1 [2] 3  All   Go Up
