Start/stop
Started by MR MISTER, 22 September 2013, 17:24:11
chrisgixer
Quote from: Vamps on 22 September 2013, 22:12:10
Quote from: Andy B on 22 September 2013, 22:05:00
Quote from: Vamps on 22 September 2013, 21:52:03
Quote from: ex taxi al on 22 September 2013, 18:25:25
It's a proper pain in the yaris if you're in stop start traffic approaching, say, a busy roundabout on a dual carriageway  >:(
You can guarantee that it will cut out about half a second before a suitable gap appears, only for you to miss it due the delay caused by restarting...
Occasionally drive an automatic 7.5t with it, which tries to solve the problem by restarting in gear the second you either press the throttle or lift of the brake, which seems a bit retarded...
I thought you could turn it off, had this on a Peugeot I was looking at some time ago and they told me it could be turned off as I did not fancy it for said reasons....... :-\ :-\
I've only driven one car with it, a B Class MB, you had to turn it of every time you started the car. No idea if they can be reprogrammed  ..... I doubt it though  :-\
That would drive me insane...... >:( >:(
Had a golf blu motion for a while. And yes, it's certainly does drive me insane too. Inbloodyfuriating!
chrisgixer
Although, now that I remember, you could cheat it slightly by lifting off the brake pressure but not releasing the brake completely, so the car was running when the lights changed.
Those cars that I notice do have it, I find amusing by pulling up way short, then creaping forward, slowly. Especially if its a cock mobile.  :-X
Pmsl
You're just a windup merchant ::)
;D ;D
Mr.OmegaMan
Isn't a diesel cheap enough to run without this gimmicky tech  ???  ;D
Fair enough on a thirsty petrol car, But diesel Na definately not, Wounder how Mr DPF likes Stop/Start around town  :o
tidla
Its all absolute rollocks.
Techos out there for real solutions as you all know, but some oil company is sitting on it till the last drop is used up.
start stop technology is not important on a single car basis but if you think hundreds of millions of cars running everyday * 365 a year * n years , it makes a difference.. :-\
Quote from: cem on 22 September 2013, 23:48:04
I bet it makes a real difference to the amount of lead that's discarded from old car batteries. ;)
Quote from: Kevin Wood on 22 September 2013, 23:57:54
car batteries can be collected and chemicals may be re-used or destroyed properly.. but you have no chance to stop harmful gases once fuel is burned..  besides this fuel also is not endless..  :-\
dbdb
Plus it should teach you to wait for enough space, then more forward slowly, then slow down gently giving the queue a chance to move before you stop meaning you don't have to keep stopping so much and nor do all the other cars behind you.
What about all the wasted fuel used in recharging those batteries, not to mention the fact that the batteries don't last.
And the longer travel times - where I work, we have enough trouble with 'tards waiting for rush hour to finish before pulling onto a roundabout, without this causing extra delays.
I'm afraid I said goodbye to the days when my car would stall at every junction when I sold my Morris Ital, and I'm not going back!
Quote from: Kevin Wood on 23 September 2013, 09:39:37
;D ;D ;D
Quote from: TheBoy on 23 September 2013, 08:55:24
steve6367
What happens when the engine stops? Does the Climate Control stop providing cold air? Do all the other electrical loads switch off so your back window mists up?
Steve
Quote from: steve6367 on 23 September 2013, 12:03:12
Steve
Fan will continue, but no cooling as no compressor with the engine off :y radio stays on as well, but can't speak for the rear window :-\
