Author Topic: No blower/aircon function  (Read 2600 times)
JH13
  • Sealand, Denmark
    • Opel Omega C 2.2 Caravan
« on: 22 September 2013, 19:51:11 »
Hi All
I am New at your Site. I am from Denmark and have just bought a Omega 2.2 16v petrol from 2000.
And now The indoor blower dos not turn on when I start the car. I have checked the fuse.
Can it be a relay or the panel?
Re: No blower/aircon function
« Reply #1 on: 22 September 2013, 20:26:14 »
Any sign that the scuttle drain got blocked, and water has entered cabin behind glovebox?
If so, suspect the fan's speed controller.
« Reply #2 on: 22 September 2013, 21:58:14 »
Blower unit up behind glovebox - try 12v across blower motor terminals to check if blower ok - no spin, blower motor kaput.  If it spins up ok, suspect spee controller (hedgehog) as TB suggests, its sited up top right of blower.  New unit very expensive - look for good used unit - (Astra G unit the same as Omega).  It just clips in ;)
JH13
  • Sealand, Denmark
« Reply #3 on: 23 September 2013, 19:26:46 »
Thanks for answers. I will check up on it.  But there is no light/power in the blower panel.
« Reply #4 on: 23 September 2013, 19:28:50 »
Ah, sorry, ignore my post above.
Have you checked both F12 and F14 fuses?
JH13
  • Sealand, Denmark
« Reply #5 on: 24 September 2013, 19:29:09 »
I am source that no 12 is checked. But not no 14. But I have just delivered The car at the painter. I have fixed some rost and changed the rear doors and rear bonnet  :)
JH13
  • Sealand, Denmark
« Reply #6 on: 03 October 2013, 16:26:05 »
Hi, it was fuse no.14  :) ;)
