Author Topic: Downloads/updates  (Read 4116 times)
pauls
  • By the sea minehead
    • Bmw x3
Re: Downloads/updates
« Reply #15 on: 26 September 2013, 09:21:17 »
Recently had the same thing on a friends laptop.Wouldn't install or update.Turned out to be a simple fix.Check the date and time. If these are wrong it can cause problems.
Talking of the above I do have to press the f1 key every time i turn on the computer. It states that the battery on the board is dead. Would this really cause my problem, if so how would i change this.
bago
  • Leicester
    • face lift 2.5 Elite bus
« Reply #16 on: 26 September 2013, 09:32:56 »
if the battery is dead on the mother board the bios will revert back to  a wrong date and time as the battery supplies the power to hold information in the bios memory when pc is switched off. normally fairly easy to replace if you look on the motherboard look for a big button size battery looks similar to battery in your key fob. get the model number and buy a replacement and change them. once changed when the pc starts up go into bios and set date and time and then this will then not be needed to be done again for a few years probably longer than you will lkeep the pc
pauls
    • Bmw x3
« Reply #17 on: 26 September 2013, 11:26:43 »
Afraid to say changing the battery didnt work. Still get nothing or warning comes up "cant find or cant open file"
Anymore ideas welcome.
« Reply #18 on: 26 September 2013, 18:07:46 »
Whilst the useless student is still localish to you, ask him to rebuild it. If the CMOS battery is shafted, I guess its old, probably not worth the effort to replace that battery.
« Reply #19 on: 26 September 2013, 20:44:05 »
its got nothing to do with date.. first you need to log in with admin rights.. re-build it.. then you will correct date-time whatever
pauls
    • Bmw x3
« Reply #20 on: 26 September 2013, 22:47:02 »
Quick update. I dont know why i did it, but i installed chrome and everything worked and it works a lost faster. All good for me. :y
  • Auckland
    • Mazda MPV
« Reply #21 on: 26 September 2013, 23:08:15 »
On the plus side it proves that it is capable of connecting to the internet & downloading :)
On the negative side it shows that there is something wrong with the IE setup. Internet Explorer is intimately connected with the inner workings of Windoze so I would strongly recommend that you don't let it connect to the internet until you have fixed it. Definitely don't use it for internet banking or eBay purchases.
I haven't got the patience to nurse sick Microsoft systems any more so I would wipe it & stick Linux on it but if you don't want to do that then at least listen to the bods who DO still have a lingering attachment to Redmond. Rebuild it (ie wipe it and re-install Windows).
Rebuild it
