Author Topic: Would one of these work with a ncdc2013  (Read 7584 times)
Re: Would one of these work with a ncdc2013
« Reply #15 on: 30 September 2013, 13:05:47 »
While they chat amongst themselves about stuff nobody understands.
Accept. The fm signal will suffer.
Er no, if the device in question was/is designed to any level of quality then the FM signal will suffer practicaly nothing.......
« Reply #16 on: 30 September 2013, 13:59:45 »
But they're invariably not. So it will :P
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #17 on: 30 September 2013, 15:56:24 »
Can you expand on that Mark because i'm genuinly interested  :)
Are you saying that the transmitter is pushing out that much power regardless of what frequency it is set to that it is swamping the other frequencys ?
« Reply #18 on: 30 September 2013, 16:20:12 »
The first stage that the FM signal goes through is a pre-amp with auto gain control, next stage will be a mixer to reduce the received signal from its 100Mhz spectrum to an intermediate frequency. These will be in the metal screened can associated with the antenna connection.
So if the injected FM signal is many times higher than that of the received signal, the PLL section will lower the gain of the preamp and consequentaly the received FM stations.
Whats more, the FM transmitters are horrific quality so they will be far from broadcast standard and will emit a wide spectrum of frequencies which will mask radio stations close in the frequency range due to bleedover.
Stereo is also questionable as the FM setup is actualy for a mono channel (Left plus right), the stereo is produced by transmitting a further audio channel  with L-R using AM supressed carrier at 38Khz above the base frequenc plus a pilot tone at 19Khz.
There is also pre-emphasis on the audio signal (they boost the amplitude of the high frequency audio before transmission and then reduce it in the reciever to improve the signal to noise ratio).
A simple low cost solution by the designers would have been to shut off the internal transmitter after a period of no audio input.
Similarly, the cost of a decent RF stage would run into the few pence to reduce losses in the device (I suspect that actualy there are very few losses and that the main issues is the AGC)
chrisgixer
« Reply #19 on: 30 September 2013, 18:28:37 »
If anyone finds an emulator that doesn't weaken the Fm signal, do tell. :)
« Reply #20 on: 30 September 2013, 21:06:06 »
Your uphill gardener has an aux out IIRC? I may possibly have a solution, as I've done on the MV6, but needs further development on the NCDC. Let me get it working on mine (TBE) first, job for those winter days...  ...once I've got one of my scopes replaced.
chrisgixer
« Reply #21 on: 01 October 2013, 01:02:53 »
Yeah audio out, map on page 5. :y
http://www.harmankardon.com/resources/Brands/harmankardon/Products/productrelateddocuments/en-us/ownersmanual/dp1_us_revb_f.pdf
