Author Topic: Camshaft and followers for Z22XE Engine 2.2  (Read 4112 times)
Character2
  • Peterborough
    • Omega 2.2
Re: Camshaft and followers for Z22XE Engine 2.2
« Reply #15 on: 03 October 2013, 20:32:24 »
Bit more info here James - http://www.omegaowners.com/forum/index.php?topic=118208.0
Don't see how those symptoms are related to the cams, TBH. :-\
Nor do I, and I suspect nor does the op ::)  Just felt James should have sight of all the ops posts on this car ;)
I'm not sure why well intentioned OOF members are facilitating what appears to be a futile replacement of cam followers when what the car probably needs is routine maintenance (2 or 3 oil changes and some lifter treatment) and calm analysis of the fault codes. After that it might need a new exhaust manifold gasket or attention to the EGR and the connections to it. :-\
Agreed mate - can't see why op feels the need to replace cams and lifters ::)
This is a separate issue to rough running when cold - I'm fully aware that cam wear is not the issue with that and agree that replacing cams / followers for that would indeed be totally futile. I was curious to see if the cams were available should I decide to fully rebuild the head at some point and to perhaps discover what other engines (if any) shared parts with the Z22XE - that is all. I greatly appreciate all those who offered constructive advice along the lines of the request.
