Brake upgrades.
Started by chrisgixer, 30 September 2013, 15:57:31
I said 17s, as occasionally I swap wheels between cars, and I dont want to loose that flexibility.
//Edit, my spare is 15, so ignore my vote. I'll stick with what GM provided for now. Sorry
Right, had a delivery today... a set of front and rear PBR calipers from a Monaro VXR 6.0 and thanks to Kevin and Robsey, summat to trial fit them to :y
Firstly, they bolt straight on, with minor tweaking to the rear dust shield and the need for 5mm longer bolts for the rear calipers 8)
Secondly the maths...(Omega in Red)
Front piston area: 2 x 40mm = 12.57mm2 = 25.1425.52 mm2 total
Front disc: 330 x 32 mm vs. 296 x 28 mm
Rear piston area: 1 x 44 mm = 15.2 mm2 13.86 mm2 total
Rear disc: 315 x 18 mm vs. 286 x 20 mm
Master cylinder bore: ??.?? mm 25.4 mm
Thirdly, they won't fit 16" wheels ::)
Pics:
Fronts:
Rears:
Discs/mounting bells are next on the list, but the first hurdle was whether they fitted, which they do, which is nice 8)
serek
how much is set of vxr calipers??
Quote from: serek on 02 October 2013, 22:11:47
These were listed on Ebay for £215.00 :y
serek
Quote from: ex taxi al on 02 October 2013, 22:14:09
yes just saw those
not bad price for set
serek
now need to find discs what will fit with this calipers
Fronts... http://www.demon-tweeks.co.uk/motorsport/brake-discs/a-p-racing-pro-5000-plus-brake-discs
Option 6 :y plus anodised alloy mounting bell.
Rears... custom made, carbon steel with anodised alloy mounting bell incorporating handbrake drum.
Pads EBC Redstuff...
serek
Quote from: ex taxi al on 02 October 2013, 22:32:16
all looking good,
so what sort of money you think will cos front and rear set up?
or just front?
Have been quoted £900+ Vat for the 4 discs and mounting bells, so including the calipers and pads, about £1450 :-\
But bear in mind that the bells need to be machined from scratch, and the rear discs are an odd thickness... a set of four cheapy Monaro discs are about £500 anyway, and the hub dimensions are different enough to be annoying, so after machining etc, probably not cheaper or easier... :-\
For reference, the full AP kit would be nearer £4k for all new parts :-X
chrisgixer
£4k ? Shit the bed! :o  Looks good though Al :y
Can't be too hard to sort a spare wheel btw. Can it? :-\
Quote from: chrisgixer on 02 October 2013, 23:26:34
Sure I can find one somewhere ::) might even be an MV6 one ;D
That 4k is for VXR8 spec brakes, using brand new components bought separately from an approved AP stockist, and includes all machining, pads and Vat... so could be broken down into more convenient chunks :y
As Edmund would say... I have a cunning plan. A plan so cunning you could pin a tail on it and call it a fox.
chrisgixer
From Haynes for omega;
Master cylinder nominal diameter
  From model year 1998
All models .................................25.40mm
Haynes forHolden Commodore gives no specs for brakes. :(
Quote from: chrisgixer on 03 October 2013, 20:33:00
Well that's a bit pants :-\
Ok a spot of Googling has found...
http://www.rockauto.com/dbphp/x,catalog,27,partnum,MC390889,d,Raybestos_MC390889.html
Which suggests a bore size of 1.25"/1.0" or in new money 31.75/25.4 mm :y
So, back to the maths...
QuoteSecondly the maths...(Omega in Red)
Front piston area: 2 x 40mm = 12.57mm 2 = 25.1425.52 mm 2 total Front disc: 330 x 32 mm vs. 296 x 28 mm
Rear piston area: 1 x 44 mm = 15.2 mm 2 13.86 mm 2 total Rear disc: 315 x 18 mm vs. 286 x 20 mm
Master cylinder bore: 31.75/25.4 mm 25.4 mm
chrisgixer
From Brembo parts catalogue
Hub hole will need machining to match omega. Omega hub outer will need machining a couple of mm to allow the disc to fit on. But apart from that, Afaict most measurements are suitable with in a few mm. ESP offset and thickness.
omega
Phaeton
Calipers
Looking at Audi q7 fronts. As Sereks recommendation. :)
